itr motor uses ctr cams? t/f?
Old Jul 21, 2010 | 05:02 PM
swizz977's Avatar
Default itr motor uses ctr cams? t/f?
is this true?
ALL JDM ITR are running CTR cams
jdm itr 96-97 are running ctr cams
jdm itr 98-01 are running ctr cams
USDM ITR are running ITR cams
only USDM 00-01 ITR have CTR cams
Old Jul 21, 2010 | 05:09 PM
BlueIntegraBoy's Avatar
Default Re: itr motor uses ctr cams? t/f?
JDM 98 Spec
USDM 00-01
Old Jul 21, 2010 | 05:11 PM
swizz977's Avatar
does this have ctr cams http://www.jdmenginedepot.com/jdm_en...Integra_Type-R
swizz977's Avatar
or does this http://www.jdmenginedepot.com/jdm_en...Integra_Type-R
Old Jul 21, 2010 | 05:27 PM
soulassassin13's Avatar
wha... false. FFUUUUUUU
Old Jul 21, 2010 | 05:37 PM
swizz977's Avatar
so which itr has ctr cams in it?
Old Jul 21, 2010 | 05:45 PM
swizz977's Avatar
http://www.ht-archive.com/showthread.php?t=1354762
Old Jul 21, 2010 | 06:05 PM
swizz977's Avatar
bump does anyone kno which itr uses ctr camss
Old Jul 21, 2010 | 06:12 PM
DCMikey's Avatar
like... really?!
Originally Posted by BlueIntegraBoy
JDM 98 Spec
USDM 00-01
Old Jul 21, 2010 | 06:24 PM
thundernoodle's Avatar
same cams.
98+ had 3 degrees duration on the intake. only diff/
Old Jul 21, 2010 | 09:04 PM
swizz977's Avatar
ok so its the jdm 98 spec and the 00-01 itr usdm
Old Jul 21, 2010 | 09:24 PM
racebum's Avatar
every single one of those itr ctr cams is so close it's nearly insane to worry about which you have. there's a 3deg difference at 1mm
Old Jul 21, 2010 | 09:34 PM
swizz977's Avatar
i want the ctr cams
Old Jul 22, 2010 | 01:08 AM
01-0720's Avatar
your dumb dude, you would never know the difference with a stock motor
but if you must have them
jdm 98 an newer motor
usdm 00-01
Old Jul 22, 2010 | 01:16 AM
racebum's Avatar
they also are the ones still sold new, hmotorsonline has pretty decent deals for a new pair
Old Jul 22, 2010 | 02:18 AM
kulo's Avatar
Old Jul 22, 2010 | 02:26 PM
swizz977's Avatar
well i would be buying the one from hmotors eather the 96 97 or 98 spec i really wanted the one with the ctr cams but the 96 97 is cheaper and he said it was better for daily driving cuz the 98 has the final drive
Old Jul 22, 2010 | 03:06 PM
swizz977's Avatar
the 98 has better headers too i think too that might b worth it
Old Jul 22, 2010 | 05:13 PM
racebum's Avatar
you can get a 98+ header for $300, your 97 manifold will sell for $150, the 98+ is marginally better but it is something like half the weight. if you're buying the whole swap better deals exist than hmotors even though some people are die hard loyal to the guys just because he runs an honest business.
Old Jul 23, 2010 | 12:24 AM
michaelz's Avatar
96 JDM headers are 4-2-1 cast items and provide peak torque at 7000rpm.
98+ JDM headers are 4-1 SS. will also give you peak torque at 6200rpm.
b18c1sircivic
Apr 8, 2008 04:49 PM
Hooch'n
Dec 23, 2004 09:13 AM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
just4fun
May 7, 2002 06:38 AM
