All stock block/head 262whp with cams
Old Jul 21, 2010 | 04:41 PM
TheMidasTouch's Avatar
Default All stock block/head 262whp with cams
Thought this would be fun for the budget minded folks. Setup is roughly:
Stock K24A2 bottom end
Stock K24A1 head
Skunk2 Stage 3 cams
RCrew Header
RBC IM
The trick was the OEM VTEC Killer setup we've been using a lot lately that lets us run the three lobe cams on the two lobe heads.
Old Jul 21, 2010 | 05:01 PM
DDTECH's Avatar
Default Re: All stock block/head 262whp with cams
enlighten how you run 3 lobes on 2.
Old Jul 21, 2010 | 05:21 PM
EdSales's Avatar
Impressive numbers on a stock head/block, but at 2 points on the graph the line goes missing. Does it dip, spike, stay the same?
Old Jul 21, 2010 | 05:46 PM
MARC P's Avatar
switch pins with in the rockers and lock one of them to vtec rockers
Marc P
Old Jul 21, 2010 | 06:05 PM
EF9_TryMe's Avatar
nice numbers. what body is this in ?
Old Jul 21, 2010 | 06:21 PM
00Red_SiR's Avatar
All Motor Mentor
That's where the pickup on the plug wires bugs out for a second or two and you lose that span of data. Spikes are not a normal part of a power curve and can be caused by a couple different gremlins. A person should always ignore the spikes for the most part and imagine a straight line connecting the normal curve at each spike point.
Old Jul 21, 2010 | 06:25 PM
By using the single roller exhaust rockers on the intake. Here's a picture of the first one we tried it on.
Stays the same. The dyno's pickup needs to be replaced. The torque spikes are a false reading however. The real peak is back at 5300 and ~195
Thanks boss. It's in my DC2
Old Jul 21, 2010 | 06:41 PM
mar778c's Avatar
Community Builder
Community Influencer
Nice job.
How well does this motor perform just tooling around town?
Old Jul 22, 2010 | 04:23 AM
MARC P's Avatar
You can also use a2 rockers and have working vtec, little better for street car and fuel
Marc P
Old Jul 22, 2010 | 05:54 AM
kulo's Avatar
nice numbers
Old Jul 22, 2010 | 08:10 AM
Originally Posted by PirateMcFred
That'll work on the intake side. The Exhaust side has no provisions for LMAs on the K24A1 head.
Good numbers, Midas. Looks like it's a dog if you fall out of the powerband though. :D
Thanks bud. This is all on an ITR tranny, so it's not so hard to keep the revs up unless I scrub too much speed mid turn. But even with the OEM cams, there was a definete lack of umph (relatively) @ 4k vs 5.5k
Originally Posted by kulo
nice numbers
Originally Posted by mar778c
Nice job.
Thanks guys
It does meh, could be better with more tuning. The idle is at 1200 now and lopes like a Yeti. I'm sure I could bring it back down by putting some more time into it but I wasn't going to run these cams for very long (still on ITR valve springs).
Agustine Reyes
Nov 14, 2017 02:03 PM
SR20S13
Feb 23, 2010 06:27 PM
VTECROAR96typeR
Dec 28, 2008 06:01 AM
2SlowDC
24
May 19, 2006 01:33 AM
THCk20eg
May 4, 2004 04:18 PM
