Motor Swap Wiring Q - OBD2a SIR-II into 97 EK
Sorry guys as I'm sure this topic has been covered, I tried the search and the FAQ pages..
I picked up an SIR-II motor for my 97 hatch and I'm not sure which wire harness to use, stock DX and add vtec wiring or the one that came on the new motor/ecu. Both are OBD2a if I am not mistaken. If anyone can chime in with an answer and any other info (any other plugs/wires that need to be modified) or a useful link, I would appreciate it.
More background:
Chasis: 1997 Civic DX Hatch with manual transmission
Motor: JDM SIR-II motor complete from H-Motors Online (RHD wire harness)
Thanks guys
More background:
Thanks guys
Easy swap, should bolt right in, and the computer will plug right in also. Use your original wiring from your car, just add the wires for vtec...the rhd harness is not needed for your swap except for a couple plugs which you can use....vtec solenoid and knock sensor
SPOONfdEK
Jun 26, 2003 03:07 PM
TheMostSadistic
Apr 24, 2003 11:15 AM
