exterior door handle stuck
Dude, how is it stuck? I had a VW the door handle came out because the latch was corroded. Try spraying some WD-40 in the lacth, but if you feel ambitious take the door apart take the latch out and clean and oil it. If it's not the latch it could be you need a new door handle.
How's the handle? Is it "stuck" meaning it won't move? Or "stuck" meaning it will move but won't open the door?
If you can still open the door, do that and remove the door panel. I'm afraid WD-40 is probably not going to help, there isn't a lot of friction of the metal parts with those door handles and latches.
suhteevin
Jan 6, 2009 09:04 PM
