B20 Vtec Misfiring :(
Old Jul 21, 2010 | 06:17 AM
MrExclusive's Avatar
Default B20 Vtec Misfiring :(
Whats up,
Haven't been on H-T in a while. I see much haven't changed
I don't have much details for you guys to begin helping me on this issue so I just have a general question to ask. Would a different ecu cause a perfectly running B20 Vtec to start misfiring???
It was running a chipped P28 before the trade then I plugged in my chipped P72 and drove off. Right from the get go it started misfiring and bogging. Once i push it to 5th gear it would misfire until it caught a spark then run like a champ after, but ONLY in 5th gear. If I down shift its the same thing all over again.
*Note*
Before the trade the car was misfiring with the P28. But problems seemed fixed. Took it for several runs and it ran like a champ through all gears no problems. Could it have also been a temporary fix maybe as well???
I dont know much about hondas or cars but it was said to be the coil or distrubitor. Its a B20B block with a GSR Vtec head.
Any help will be appreciated
Old Jul 21, 2010 | 08:30 AM
apexi_rsx's Avatar
Default Re: B20 Vtec Misfiring :(
change plugs cap n rotor lately? how many miles are on them? if not ignitor may be on its way out
Old Jul 21, 2010 | 08:41 AM
EdSales's Avatar
Originally Posted by MrExclusive
Whats up,
*Note*
What is the ECU chipped with?
Old Jul 21, 2010 | 09:14 AM
Sr420Det's Avatar
yeah cause u have no idea whats on the base map, but make sure your ignition system is in good working order.
Egchico69
Jan 11, 2013 06:35 PM
dansXR2
Mar 10, 2010 08:36 PM
efjones9
Jan 31, 2009 12:41 PM
ballerboi23
Jun 23, 2007 06:54 PM
B20inDCinLBC
Aug 20, 2006 12:42 AM
