EK tranny on EG?
Old Jul 20, 2010 | 04:42 PM
alx_90ef's Avatar
Default EK tranny on EG?
ok i know an y8 trannie will bolt on to a z6. but in the automatic world are they the same? can i put an automatic y8 tranny on an automatic z6? going to an eg of course
Old Jul 20, 2010 | 04:44 PM
EJeff8's Avatar
Default Re: EK tranny on EG?
I just learned this myself actually. All D series trannies work with all D series engines. So anything from 92-2000
The Y8 and Z6 are basically definitions of the head with slight mods in the blocks (nothing drastic though)
Old Jul 20, 2010 | 04:48 PM
alx_90ef's Avatar
yeah i know they fit. but like all the solenoids and lines etc are they the same?
Old Jul 20, 2010 | 04:55 PM
EJeff8's Avatar
From 92-00, all sensors and plugs will line up.
I myself am putting a '92 Z6 Ex tranny on my '00 Y8 Ex. I'm putting the ends of the spectrum together and it'll bolt up and plug in just fine
Old Jul 20, 2010 | 04:56 PM
EJeff8's Avatar
What you may have a problem with is the automatic in the ecu. If you go OBD1 to OBD1,or OBD2 to OBD2, you'd be fine. Idk about crossing the OBD's though.
Old Jul 20, 2010 | 06:11 PM
94EG8's Avatar
Seagull Management
Nope, transmission will physically bolt up but from an electronic perspective its completely different. ('96 - '00 Transmissions have a mainshaft and countershaft sensor, a linear solenoid and a 2 shift solenoids that '92 - '95 trannys don't have) '92 - '95 trannys are better transmissions anyway, especially the M24A found in the '92 - '94s, the A24A found in the '95s just doesn't seem to be as good, although they are 100% interchangeable.
Old Jul 20, 2010 | 06:23 PM
EJeff8's Avatar
^Well, this comment makes me feel even better about my swap!
amej8
Jun 3, 2008 01:15 PM
GSRSnowWhite
Jan 1, 2008 10:55 AM
notstreetlegal
Apr 10, 2007 09:49 AM
