Squeal when under acceleration
Old Jul 20, 2010 | 02:08 PM
ikeray's Avatar
Default Squeal when under acceleration
When I step on the gas in my 94 accord ex, I get a loud squeal (don't know if you can hear it outside the car but its plenty loud inside the car). at first I thought wheel bearings but I just replaced those and its still there, its weird because it doesn't happen when car isn't in gear (ie neutral or park). it doesn't normally do it until I get to 2000-2500 and give 1/2-3/4 throttle (passing or accelerating into traffic). under normal acceleration (ie shifting near 2000-2500rpms) I don't hear it at all.
I don't know if its related, but the hose under my intake that goes to my resonator chamber (located under air filter) has a hole in it.
Old Jul 20, 2010 | 02:20 PM
GhostAccord's Avatar
Default Re: Squeal when under acceleration
Check your accessory drive belts, power steering and alternator & A/C. Make sure they aren't too loose or worn.
Old Jul 20, 2010 | 07:10 PM
jdadams12's Avatar
Does it do it when the AC is off? If not, then it is the AC belt as mentioned in the above post.
However, if it does it even with the AC off, it could still be the accessory belts.
German_Accord
11
Oct 5, 2013 09:18 PM
eldog80
Mar 2, 2012 11:56 AM
RnEpmc
Aug 22, 2004 08:53 PM
rubens
Sep 4, 2003 08:23 AM
abeaujuin
Aug 29, 2003 01:01 PM
