keep blowing radiator fan fuses.... WTF
Old Jul 20, 2010 | 10:05 AM
esedulerp5tenin's Avatar
Default keep blowing radiator fan fuses.... WTF
in the ongoing battle between my overheating car and i......
i was bleeding the coolant today, wondering why my fan wouldn't come on, and found the blown fuse.
replaced it with another 20A, started the car, and this one blew as soon as the fan came on.
replaced it again (20A), the new one blew as soon as I STARTED THE CAR!!!
ok, so i have a short somewhere, correct?
the only electrical work i've done on the entire cooling system is soldering the rad. fan to the harness, that's it.
P.S. the fan obviously works, and i hear the relay clicking when jumping the fan switch connector. clicking means the relay is working?
Old Jul 20, 2010 | 07:11 PM
92civlude's Avatar
Default Re: keep blowing radiator fan fuses.... WTF
Unplug the fan motor, install a fresh fuse. If it pops when the fan motor is reconnected, Its a faulty fan motor.
Old Jul 20, 2010 | 07:46 PM
Enzo15's Avatar
Check your solder points where it meets the harness to make sure that there is no short somewhere.
Old Jul 20, 2010 | 08:33 PM
so basically cut the wires to the fan (since they're soldered together), resolder, new fuse, and see if it blows?
since i'm getting a feeling this new (to me, at least) FAL slim fan is on its way out, i'm gonna connect/solder my old no-name slim fan up tomorrow, see if the fuse blows, then i'll narrow it down to the fan or not.
Old Jul 21, 2010 | 08:02 AM
TurboBB2's Avatar
I had a similiar problem, i just ran the fan and tied it into the positive wire that goes into the fuse box so the fan always stays on. Haven't overheated since.
Well, that was my solution but my lude isn't a DD i drive it 2 or 3 times a week, so.. that might not be the best for you.
Old Jul 21, 2010 | 09:04 AM
that's not a bad idea since mine is boosted too, and is very slowly becoming my non-DD hahaha.
Old Jul 21, 2010 | 09:10 AM
TurboBB2's Avatar
lol yea. getting an aftermarket radiator helps a bunch too prob a good 30-50% extra cooling if you get a good name brand.
Old Jul 21, 2010 | 09:17 AM
i just bought this mishimoto/FAL combo from some dude on PP who claims less than 6 months use. its to replace my generic ebay rad/fan that was leaking.
so just this morning i swapped the FAL fan for the ebay slim fan, was bleeding the coolant for a solid hour w/ the fan kicking on 10-15 times, and so far it looks good. i'm gonna start praying it did the trick.
Old Jul 21, 2010 | 09:29 AM
TurboBB2's Avatar
seems like he sold u a bad fan
Old Jul 21, 2010 | 10:46 AM
mehh, it was working for about 3 weeks now, and i guess decided to die just now. so it was working when i installed it, so i'm not puttin the dude at fault. just shitty luck on my end i guess.
Old Jul 21, 2010 | 11:03 AM
TurboBB2's Avatar
tru
dubyada
Honda CR-V & Element
Aug 21, 2014 10:12 AM
EJ8Squad919
Jun 30, 2014 06:46 PM
fatl13ert
Oct 22, 2012 12:41 AM
2Cleezy
Sep 2, 2005 08:48 AM
JDM_SOHC
Aug 10, 2005 09:53 PM
