Is my TPS bad?
Old Jul 20, 2010 | 05:48 AM
Reyracer19's Avatar
Default Is my TPS bad?
Car: 96 Hatch, stock under the hood
ECU: No CEL's and took it to autozone to scan and no codes show up. I reset ecu as well.
The problem:
Car runs normal but the minute you approach a red light it idles down to 100-200 and eventually dies.
What I already did:
Took out the IACV cleaned it (but it was pretty much clean) removed any air from the cooling system. Tightened the throttle cable.
Tested the voltage on the TPS and got .45 average and a steady climb as throttle is applied.
So after doing all that the car was running descent (the idle was a little high but it wouldn't drop) Today I got in my car to come to work and it wants to die again.
Please help.
Old Jul 20, 2010 | 05:58 AM
Former User's Avatar
Default Re: Is my TPS bad?
When you unplug the IACV connector with the engine idling, does the engine idle speed increase?
The throttle cable should not be tight. Adjust it to have about 1/2" of slack.
Old Jul 20, 2010 | 06:09 AM
Reyracer19's Avatar
I'll try disconnecting the IACV when I get home. And currently the throttle cable is tight since that raised the RPM's a bit ...It was my backyard solution as I need to get to work and back. But obviously the car is compensating for the higher throttle and still dropping the idle.
Old Jul 21, 2010 | 01:50 PM
Reyracer19's Avatar
When I disconnect the IACV, the idle goes up some and when I plug it in it goes back to the 700rpm mark +/- .
Is this normal?
Old Jul 21, 2010 | 02:05 PM
Is this normal?
Yes, the IACV seems to be working.
Try this:
Old Jul 21, 2010 | 05:09 PM
Reyracer19's Avatar
I"ll give that a go, what does "112-turn" mean is that like 1/4 turn ?
And big thanks for taking the time to help, I'm so tempted to put this engine in the bottom of the ocean some were and get a B-series
Old Jul 21, 2010 | 06:53 PM
It should read 1/2 turn.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
cdmef
Jul 3, 2011 06:03 AM
shooitzlinh
Jan 8, 2005 09:52 PM
ccivic
16
Jan 4, 2005 12:01 PM
1HotHonda
Mar 30, 2002 07:35 AM
