Car makes noise when i start it up. help.
Old Jul 19, 2010 | 11:59 AM
panchlow's Avatar
Icon2 Car makes noise when i start it up. help.
I got a 94 eg..
About 2-3 weeks ago i turn my car on and it made a squeaking noise and it went away and then my car turned on..
i didnt really car about it much because it was only one time, but now everytime i turn it on, it makes the noise all the time
what could it be? i have no clue.
Old Jul 19, 2010 | 12:03 PM
airric's Avatar
Default Re: Car makes noise when i start it up. help.
alternator
Old Jul 19, 2010 | 12:12 PM
panchlow's Avatar
does anything bad happen if i dont fix that??
Old Jul 19, 2010 | 12:13 PM
Former User's Avatar
Could be a loose drive belt or a bad pulley bearing. Try removing the drive belts one at a time to see whether removal of one makes the noise go away.
Old Jul 19, 2010 | 12:31 PM
panchlow's Avatar
it just does it when im turning the key and then when the car starts, it stops.
Old Jul 19, 2010 | 12:33 PM
Is the noise coming from the starter motor on the passenger side of the engine?
Old Jul 19, 2010 | 12:36 PM
panchlow's Avatar
nahh, i kno it doesn't come from over ther,
it come from the right side of the engine(driver side)
Old Jul 19, 2010 | 12:38 PM
The driver's side is by convention called the left side.
Do the drive belt removal tests.
Old Jul 19, 2010 | 12:41 PM
panchlow's Avatar
yeah, ima check all that 2morrow..
anything bad happen if i dont fix this??
Old Jul 19, 2010 | 12:43 PM
You car could have a sudden breakdown that leaves you stranded.
Old Jul 19, 2010 | 12:45 PM
D16SiHatch's Avatar
Why would you not fix it?
since we don't know where the noise is coming from how can anyone tell you for sure whether or not it could cause something "bad" to happen. certainly nothing good can come of leaving it as it is right?
Old Jul 19, 2010 | 12:49 PM
panchlow's Avatar
i never said i wasnt going to fix it.
just not right now at the moment.
Old Jul 19, 2010 | 12:53 PM
D16SiHatch's Avatar
well then figure out what it is and go from there. most likely just an old or improperly adjusted drive belt, but better to be safe and check.
Old Jul 19, 2010 | 12:56 PM
panchlow's Avatar
yea..
ALSO let me add something to that..
i was cleaning my engine with the spray hose and degreaser to get all the dust out, well when i turned the engine on to help it dry it made that noise.
could i have gotten water somewhere i shouldn't???
this was the first time it ever happen..
Dm914
Dec 28, 2015 03:31 PM
Montezj1
Honda Civic (2006 - 2015)
Jul 12, 2013 09:48 PM
danno33
17
Apr 20, 2011 05:36 PM
Silvteg95
Aug 1, 2005 11:28 AM
