parking lights inop in ej?
Old Jul 19, 2010 | 09:14 AM
TrackRat's Avatar
Default parking lights inop in ej?
well i swapped in a black dash into my ej and noticed when i gave everything a test run my parking lights do not come on. however when i hit my hazard lights they will work as well as my turn signals. rear parking lights work. did i miss a simple connection when connecting my harness to everything? im confused and cant seem to find the issue. tia
brian
Old Jul 19, 2010 | 10:48 AM
Former User's Avatar
Default Re: parking lights inop in ej?
What year? The bulb has a dual filament, one for the turn signal and one for the parking light. Do you have the correct dual filament bulb installed? If the bulb is fine, then check whether the parking light power wire has battery voltage with the light switch on. If not, check your wiring job.
Old Jul 19, 2010 | 01:23 PM
TrackRat's Avatar
i have a 95 coupe. i do have replacement bulbs did not consider the dual filament ill replace them when i get home
acurar
Jun 8, 2010 08:14 AM
CPreston
Lighting
May 21, 2009 11:35 AM
Mfoehrkolb
Sep 22, 2008 05:56 PM
bmxer
Feb 2, 2008 07:00 PM
CRX_Type_R
Nov 9, 2007 05:02 PM
