Help with JDM seat install
I have a 00 Si. I also have a ride side DC5R Recaro seat. What exactly will I need to buy and do in order to install this right side Recaro seat into the driver side of the 00 Si?
I don't want to have to cut and reweld brakets. Rather just buy new and correct fitting brackets. Where can I buy a bracket? I checked ebay and wasn't sure which I need. I also know I am going to have to swap the seatbelt latch. How is this done? What else?
Thanks to anyone who can help.
From what I can tell, I'd rather get a bracket or whatever I need. I'm just not sure which bracket is lets me put a DC5r seat into my 00 Civic....
WRONG!!!
OP: You need OEM EK9 CTR rails for the driver side, or bottom mount Recaro rails meant to fit a 96-00 Civic. Wedge Engineering makes rails or you can buy pre-made Bride RO rails. There are a few manufacturers in Japan, but you probably won't be able to obtain them unless you use a YJA service.
WRONG!!!
Would either of these fit (assuming I can just buy the left side)?
http://n1concepts-inc.blogspot.com/2...t-sliders.html
or
http://www.rhdjapan.com/feel-s-low-p...eat-rail-56242
Where is the best place to get the OEM CTR rails? I can't find any....
or
or
WRONG!!!
As you could see, I only quoted your first post. Please refer to the context before replying. And I did read your last post, but since you claim you were lazy and told the OP to search, I provided a more detailed answer.
Because you can't do a seat pan swap. The right or left Recaro seat can be used as either the driver or passenger seat. The bolt pattern on the bottom is the same with either seat. The only difference is the recliner **** will be either toward the middle or outside of the car depending on which seat you have and what side you put it on.
LOL
I just ordered the bracket and slider from Wedge Engineering. Should be good to go in about a week and a half..... Hopefully everything works out....
_EF9
Jun 7, 2008 11:35 AM
1 SiC EJ1
May 22, 2005 01:50 PM
Turbo'dMex-A-Keen
Jul 2, 2003 10:18 PM
