EM1 armrest on 97 cx? SEARCHED
It will fit.
But it will be a bit loose because you can only screw it in with the 2 screws in the front. There are no higher up ones in back to hold it in place.
It will fit as mentioned earlier, and that little bracket to mount it is cheap and easy to get. Keep in mind that the plastic parts in 99-00 Civic's have a darker gray then the 96-98 models, so if you put the newer armrest in, it will not match.
96-00 civic's are getting much easier to find at the junk yard now, i see them all the time, and cost is only like $15 complete
Was 98 or 99 the crossover year? I know for sure, my 96 had a lighter gray plastic, the arm rests were definitely different in color that the 99-00
I've held up a TYPE F (Light Gray / Excel Charcoal) part to my TYPE K (Dark Gray / Classy Gray) interior and it was even pretty close, though far enough that if I were to install it in my car it'd be a noticeable difference.
I was just surprised with how close TYPE F and TYPE K looked right next to each other. TYPE K was darker and more blue and it'd drive me insane to have the mis-matchd parts, but it wasn't as far off as I expected.
nonpoint986
Mar 24, 2010 09:08 PM
siblue_gzer
Apr 28, 2008 12:06 PM
cruzersi99
23
Feb 17, 2006 08:21 AM
Collateral
Dec 1, 2004 07:44 AM
