Blew up >>> into a build thread
Bump if viewed please!! i'm stoked about this build!!!
Blew up now i'm doing a complete build!!!
anyways....
Here we go guys, wisdom help and parts are needed!! and greatly appriciated!
HOW IT HAPPENED:
SO on my way home from OC maryland 2 weeks ago i noticed my car had a distinct miss... assuming my ancient plug wire were finnally failing i stopped and opened the hood
i let it idle and confirmed that i had spark
only a few things could lead to a no fire issue
after a compression test i deemed it to be such.. <50lbs compared to the others running 198lbs
2 hours later i had the motor out head off and valve out
it had "burnt" a valve... how idk that is what i am trying to prevent!!!
looks like a pie cut from the back but a halvf moon from the front..
buddie mikey had had the same exact valve go bad two years before the same exact way ... in this same car...
keep tuned in for the results!!!
SPECS ON REBUILD:
car -2000 B18c1 Gsr
B4 she came out
ORIGINAL GO FAST BITS:
sk2 IM
AEM shortram
crappy dc headder
AEM tru time cam gears
Ngk wires
B&M Fpr
NEW REBUILD BITS AN PIECES:
so far i have a few parts on the shelf ready to go !!!
type R 81.5mm full floating pistons cut for ls width rods
Eagle forged ls rods (i know theyre crap but this is a budget build!!!)
full gasket set for b18c
Crower stage 3 #403 NA cams (want stage 2)
crower dual valvespring and Chromoly retainers
Fererra std. size flat faced valves
supertech valveguides
STUFF I NEED FROM THE STORE:
bearings
belts
hoses
Wpump
Opump
beer
STUFF I NEED FROM OTHER MEMBERS:
What i need lmk if you have is
LS crank (not cut or micropolished) factory or forged lmk
rc injectors around 340
catch can
ANSWERS I NEED:
?HOW AND WHAT TO DELETE FOR DELETING THE CHARCOAL CANISTER!!! - AND SHOULD I??
OK heres a pic of pistons in comparison,
seems cleaner and free of debris.... maybe from running fuel thru it w/o ignition... idk
motor only has 115k miles but did use some oil...
heres the rest of the valves...
anyways....
HOW IT HAPPENED:
SPECS ON REBUILD:
car -2000 B18c1 Gsr
B4 she came out
sk2 IM
AEM shortram
crappy dc headder
Ngk wires
B&M Fpr
bearings
belts
hoses
Wpump
Opump
beer
catch can
ANSWERS I NEED:
That's what happens when your motor has a lot of miles on it and the valve guides/seals start leaking. Just look at your pictures and you'll see all the carbon buildup around the valves. After a while it builds up on top of the valve and prevents it from sealing which causes it to overheat and "burn". They often shatter a small pie piece out of the valve like that.
yea seems like they were especially bad on #1 clynder... same thing happened 2 years ago the same way but wasnt fixed right... thanks for the help!!!
so yea what about my other concerns with the brake lines and what about spring locators???... any ideas???
thanks!!!!
yesterday i got a few things done....
keeping the fuse box where it belongs but tucking most of the wires and deleting the abs setup... (running brake lines low...)
LOOk what i did to fund my more of my project today,.... sad to see her go but somone offered so its gone!!!....
I also welded some of the unnessasary holes shut in the passenger side and rad support of the engine bay that i didn't need...
heres behind the passenger side headlight where the abs module was...
the nasty looking fluid is a little bit of brake fluid and some water to prevent fire!!! haha
heres the rad support!! not sure how much more i'm filling....
Change over to a OBDI ecu and just cut the plugs or cover them.. the canister isn't needed.. and it will leave you some run for a setup if you want to run a catch can setup..
There's really not alot, take your wiring harness and just clean it up, make sure its all covered and looks nice..
what exactly are you asking?
And i'm asking what lines need to go where after i remove the emissions stuff b/c i'll have open vac lines... maybe a link to a "how to" thread
and why do ppl say it makes them fail emmisions?? what causes this?
bump, i am about to start building my 01 gsr.. same misfire symptoms, dont know if its a valve, but i plan on new pistons, and valvetrain. ugh.
i want it out but if it will cause emission problems i wanna know haw to put er back in b4 the test...
Pensylvania... i'm not concerned about the visual just the plug in part my neibor does my inspection but a loacal shop sniffs it... i'm assuming if it just purges the presurized fuel tank vapors into my manifold i don't need it??...
If so i cap the lines? and what do i do with the "valve" that mounts on to the back of my intake mani??... i'm assuming cap it and delete the wires and all the hoses??
