i need help on installing coilovers?
Old Sep 15, 2002 | 06:31 PM
mark72's Avatar
Default i need help on installing coilovers?
which tools do i need to properly install ground control coilovers on my integra?
Old Sep 15, 2002 | 06:37 PM
-Gambit-'s Avatar
Default Re: i need help on installing coilovers? (mark72)
you might want to rent a spring compressor and your basic hand tool, 0oh and some allen wrenches
Old Sep 15, 2002 | 07:13 PM
hadboosttroy's Avatar
deep socket set
torque wrench
breaker bar (not a necessity i guess but it helped me)
allen wrench
pretty much just basic stuff. are u doing shocks as well? you may need a spring compressor...
Old Sep 15, 2002 | 07:42 PM
TimoneX's Avatar
New User
Default Re: i need help on installing coilovers? (hadboosttroy)
You will need a spring compressor. Or you can take them somewhere, have them compressed and get the OE dampers off. You probably won't need the spring compressed to install the GCs though.
Old Sep 15, 2002 | 08:22 PM
-Gambit-'s Avatar
Default Re: i need help on installing coilovers? (TimoneX)
no you dont need the compressor to get the ground control on the damper, you only need the compressor to get the stock spring off the damper, just because the stock spring is alot longer then the groundcontrol spring and its under alot of pressure.
Old Sep 15, 2002 | 11:06 PM
mark72's Avatar
i am not doing shocks
Old Sep 15, 2002 | 11:08 PM
mark72's Avatar
ill be doing it on wedsnday so i hope i dont **** up anything. thanks for the advice and tips i will post up anything else if i have any porblems.
mickey1
Suspension & Brakes
Feb 6, 2008 04:32 PM
Kyles ej1
15
Sep 25, 2004 07:33 PM
All_JDM_Si
Sep 29, 2003 11:00 PM
95si
Oct 11, 2002 07:16 PM
