99 Si / GSR swapped, VTEC AND ECT PROBLEMS!
So I cranked my car up today and was driving to work and my damn check engine light comes on. I jump the service pin and it pulls up code 6 (Engine Coolant Temperature Sensor)?.*
**99 EM1, stock harness, chipped p28, GSR swap**
I have a couple of questions:
1. What exactly does this sensor do and where is it located? (If I remember rcorrextly it's on thermostat housing but I'm not too sure)
2. How can I test to see if it's good?
3. Could this make my VTEC not engage?
Any help is appreciated! Thanks!
Josh*
Josh*
wrong vtec will cross if cel is on know that cooloant tempp sensor could be the problem why ur vtec is not working does ur coolant guage still work?with i bad sensor it might be telling the ecu that the engine is still cold witch vtec wont work unless motor is warm
also known as TW sensor/ECT sensor not the coolant temperature sensor that goes to the gauge
I think it may not let VTEC activate because this sensor lets the ECU know the coolant temp and alters ignition/fuel curves accordingly
Problem solved it was a break in one of the two wires lol
psycho_civic
Oct 23, 2003 08:33 AM
