b16 overheating problem
I have a 96 coupe with a b16a2 and for the last month it overheats when it wants to but only when its at a dead stop for a while. First I took out the thermostat and ran without one to see if that was the problem (didn't fix the problem). I aired out the system and it won't overheat for a while. Then I changed the radiator with a dual core one, put a new oem thermostat and aired out the system with the a/c setting set on heat. Few days later with the car sitting for a while at a dead stop the car started to overheat again. My question is what else should I change before i start thinking about headgasket and water pump.
ac, b16, b16a2, changing, fault, honda, light, overheading, overheat, overheating, overheats, problem, problems, s2000, thermostat
