I have a loose rt4wd dseries tranny
Old Jul 18, 2010 | 09:17 AM
eklum's Avatar
Default I have a loose rt4wd dseries tranny
im curious if anyone out there is looking to make an adapter plate and would need to use my spare tranny the bell housing is cracked but it should be good enough to make a mock up adapter plate i know noone has done this yet so if you own a CNC machine or work somewhere that does and would like to take advantage of this time since these trannys are impossible to find just trying to help the cause if any one needs any info or would like me to take mesasurements let me know via PM thanks
Old Jul 18, 2010 | 09:25 AM
highroller54's Avatar
Default Re: I have a loose rt4wd dseries tranny
adapter plate for what? The bell housing has the same bolt pattern as any d series so I'm not sure what your going for.
Old Jul 18, 2010 | 09:39 PM
eklum's Avatar
i was under the impression the intermediate shaft didnt bolt onto the bseries blocks and it didnt bolt onto the fseries or hseries all the research ive done came up with nothing . so i figured itd be worth a shot.
Old Jul 19, 2010 | 06:13 AM
you are right it wont bolt to anything but a d series but you can run a b to d but you would be on your own for the intermediat shaft.
Old Jul 19, 2010 | 08:20 PM
eklum's Avatar
okay so heres the clearance issue people talk about im assuming its a tight fit with a stock dseries setup id have to think all that would need to be done is cut and weld a custom oil pan for the f22 would all that would be that is needed. then some how fabricate a bracket that adapts the int shaft to the f22 block . does any one have pictures of the intake main fold side of the f22 block?
egb18c5
Transmission & Drivetrain
Jul 8, 2009 05:46 AM
UltimX
Oct 19, 2006 09:21 AM
86gxl_fc
Jul 20, 2005 04:41 PM
CiViC dRaGsTaR
May 23, 2001 10:10 AM
