breather filter question and intake help
Old Jul 17, 2010 | 09:30 PM
Duc_du's Avatar
Default breather filter question and intake help
1. so today i bought those small filter for the valve cover because my friend told me it will help cool it down and look nice. went on line did some research and some say its bad (too complex to understand) and some say it wont do no harm. if its bad do i just put back the cover on it? so what do the experience HT got to say about it?
2. normally i see a lot of people with a tube that connect from the vc to the intake but mine doesn't. it is connected with something called "denso sensor map". im totally confuse what to do about this.
with breather filter
with cap
Old Jul 17, 2010 | 11:01 PM
jonesEK's Avatar
Default Re: breather filter question and intake help
TTT id like to know too.... my intake doesnt have one as well... a cop saw that (in cali) and said THATS ILLEGAL! ref ticket for a fawking intake FTL
Old Jul 17, 2010 | 11:16 PM
Duc_du's Avatar
that suck. so should i just drill a hole and run a tube from the vc to intake???
Old Jul 17, 2010 | 11:53 PM
DDTECH's Avatar
Unless your using the stock intake system its not need, a filter allows for crank case breathing through the valvecover , its not the most opitum way to vent crankcase pressure but its fine if you have a mild bolt on or stock motor..
Old Jul 18, 2010 | 01:33 AM
DCRB's Avatar
the denso map thingy could be your IAT (intake air temperature) sensor. i too have heard mixed things about the breather filter, i just put a hose back on mine...
Old Jul 18, 2010 | 01:50 AM
imbest123's Avatar
^ this.
ive actually never seen the cap but what it does is route the gases to your intake. there may be some oil moisture but nothing extreme. for an all motor build its pointless to get a breather filter and yes, adding a breather filter will fail any emissions test that requires a visual and it is illegal in all 50 states.
Old Jul 19, 2010 | 12:36 AM
Duc_du's Avatar
bump. so should i drill a hole in intake connect a tube to vc??
m0squ1t0
Sep 6, 2009 10:00 PM
young geezer
Aug 3, 2009 02:34 AM
kennybintegra
Mar 13, 2006 02:38 AM
andyp
Jun 7, 2004 05:12 PM
B00ST2nR
Apr 21, 2003 03:25 PM
