whre is the low port located on a 02 accord 5 speed?
Old Jul 17, 2010 | 08:58 PM
ssgferrell's Avatar
Icon6 whre is the low port located on a 02 accord 5 speed?
Hey there. My work car is hot as you know what. I purchased it 2 yrs ago and the air was ok to me. Now it is gone. I know if r12 is in it, I will have to covert it. My issue is where is the low port located and what charateristics it has so I know that is what is is?
Thx,
ssgferrell
Old Jul 19, 2010 | 07:15 AM
sgraham01's Avatar
Default Re: whre is the low port located on a 02 accord 5 speed?
your 02 will have r-134a installed. the low pressure fitting will be in the larger of the two a/c lines coming off the evaporator (through the firewall). Trace the larger pipe from the firewall and the service port should be attached to it. It will probably have a plastic screw-on cap and the valve inside will look like a tire valve.
barfo
Jun 1, 2018 08:41 AM
Mxrider52
Jul 27, 2008 12:27 PM
Lowski
Jul 22, 2007 08:14 AM
Duce5123
Jul 25, 2005 07:25 PM
Cereal_Killer
Oct 1, 2001 01:08 AM
