Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic Overheating Issue...
Old Jul 17, 2010 | 07:57 PM
Hollywood_Cal's Avatar
Icon2 2001 Honda Civic Overheating Issue...
I got a 2001 Honda Civic LX 2door in the past month it was overheating.I change the water pump along with the timing belt & the thermostat.Also change the motor & a/c filters.The car temp never reach the H well almost.There's cooling inside and no leaks.The car run normal now with the right temp but when turn the a/c on it starts to rise then i need to shut it off and it goes back down to normal.On a super hot %90 day it rise about 3 or 4 lines and when i slow down on the gas it goes back down.The fans work but to me they look like they moving slow idk if i need a new fan clutch or what let me know thx.
Old Jul 19, 2010 | 06:57 AM
EM2abe's Avatar
Default Re: 2001 Honda Civic Overheating Issue...
Check to see if there's air in the system.
Old Jul 20, 2010 | 05:31 PM
Is there a test like to know if there's air in the system or any signs to see if there aint air coming in.
Old Jul 23, 2010 | 03:41 PM
Paso516's Avatar
You checked your coolant?? And also I think I heard that if the timing belt is off, the temp will be higher. I changed my water pump & timing belt just yesterday & I heard my mechanic saying something of the sort.
Old Jul 23, 2010 | 06:56 PM
It Wasn't Me's Avatar
Originally Posted by Hollywood_Cal
Is there a test like to know if there's air in the system ...
Burp the cooling system. You can use a radiator attachment, like this...
.. which can be found online, or possibly at a local auto parts store.
Or you can just leave the radiator cap off (or just set on top of the filler neck to prevent any potential splashing) and leave the engine running until the radiator fan cycles at least twice and/or until you no longer see any bubbles in the coolant. Keep the coolant topped-off (base of filler neck)
If you use one of those attachments, keep the reservoir about 1/3 - 1/2 full. I recommend getting one, they work great and can be used on a variety of automobiles since they come with different attachment pieces.
Old Jul 25, 2010 | 05:17 PM
thx for the tips ill keep ya update
Old Jul 26, 2010 | 05:14 AM
Slidin'Sidewayz's Avatar
The cheapest way is find a plug at the highest point in the water system. IE i took out a sensor right above where the top radiator hose connects and left it out while filling the radiator till it was flowing without any air then put plug back in. easy and free
Old Aug 5, 2010 | 06:44 PM
Default car temperature rise while idle..
Ok check this out its back.I notice when its super hot out with humid air when i stop @ a light my temp gage start to rise about 2 bars or 3 once its green light and air comes in it goes back in.Thermo and water pump has been change the fan comes on once it reach that temperture to come on and off and there coolant with no leaks.Could it been the temperature sensor or Cooling Fan Switch - Radiator this is a 2001 honda civic use to be own by a women i dont think she ever change anything smh let me know guys...
Old Aug 6, 2010 | 09:10 AM
EM2abe's Avatar
Default Re: car temperature rise while idle..
I think it would be highly unlikely that the temp sensor would go out. The fan switch might be bad as well. You can test it or you can just replace it. Is your coolant riding unusually high in your coolant resevoir???
honda0410
Jul 28, 2010 06:03 PM
nik1703
Jun 21, 2010 04:15 PM
Gant
Jan 29, 2009 04:52 PM
Utilitarian
Sep 14, 2007 11:20 AM
tub_sephiroth
Jan 20, 2003 05:58 AM
