1999 ex with a big hole in the block
Old Jul 17, 2010 | 03:51 PM
chuck75's Avatar
Default 1999 ex with a big hole in the block
My sister ownes the 1999 civic ex with the sohc vtech. she blew it up and put a hole in the block. I called all over the place to find one. theres lots out there but there not cheep by no means. as she has limited funds, I bought a engine from a warehouse for 600 long block. not bad right? so anyway as I get it home, I unload it next to the one that came out of the car to find theres a small diffrence, theres a extra vacume port standiding straight up right between the two middle injectors right up against the head.
So I call around and every one is telling me the new used engine that I bought is from a 1997 or older and it should have another sensor for the cam. anyone ever heard of this?
Old Jul 17, 2010 | 04:03 PM
HPTautosport's Avatar
Default Re: 1999 ex with a big hole in the block
Swap the intake manifold from the old motor to the new one. The 99-00 Ex manifolds are slightly different than the 96-98. Use your old engine harness as well. I believe all the sensors are the same. GL.
Old Jul 17, 2010 | 04:15 PM
chuck75's Avatar
thanks HPT. I really dont want to swap heads.
Old Jul 17, 2010 | 04:26 PM
You don't need to swap the heads....just the intake manifold and buy a $12 gasket.
Old Jul 17, 2010 | 04:30 PM
chuck75's Avatar
so theres no "extra cam sensor" on the 1999 heads?
Old Jul 17, 2010 | 04:42 PM
apexi_rsx's Avatar
nope everything is the same just swap the intake manifold and your good. the newer ones had air injection holes in the manifold thats what that nipples for and you dont need it. all the other sensors are plug and play
Bense
454
Jan 26, 2024 03:11 PM
TruD16Z6
13
Oct 13, 2012 08:26 AM
tayjacwor
Apr 24, 2010 06:16 PM
ef9wpb
Southeast (Sales)
May 20, 2007 08:30 PM
GENERAL LEE
Apr 4, 2003 06:08 AM
