Sway Bars and Strut Tower Bars..
Old Sep 15, 2002 | 05:34 PM
SystemGSR's Avatar
Default Sway Bars and Strut Tower Bars..
I have a GSR and i think it's about time for some more suspension upgrades. I already have the ITR sway bar. I was looking at the the mugen front sway bar. It's 22mm but i noticed the R version is 26mm. What would you guys recommend for my GSR and why? Also i'm probably going to be buying tower bars for the front and back as well. Any recommendations ?
Old Sep 15, 2002 | 05:43 PM
Flux's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (SystemGSR)
I would hesitate throwing a 26mm rear sway bar on the car without balancing it with other modifications of the suspension such as a different front bar, adjustable dampers, etc.
Old Sep 15, 2002 | 05:47 PM
SystemGSR's Avatar
do i even need a front sway bar? i mean the GSR one is 24mm right? mugen would be a downgrade...
Flux, I already have the rear ITR sway bar. I also have Tein NA's. I will probably be purchasing both strut tower bars at the same time.
[Modified by SystemGSR, 6:49 PM 9/15/2002]
Old Sep 15, 2002 | 10:46 PM
SystemGSR's Avatar
dont ignore me damit!
Old Sep 15, 2002 | 11:00 PM
92TypeR's Avatar
FSAE
24mm is fine for the front. 26 is pushing it for the rear.
Just mess with dampening force, and balance out that beast.
Old Sep 16, 2002 | 12:21 AM
SystemGSR's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (92TypeR)
what about the tower bars...
Old Sep 16, 2002 | 12:22 AM
Type Goch's Avatar
New User
ITR strut tower bars are good.
Old Sep 16, 2002 | 12:25 AM
$pecial K's Avatar
You need some "Tein!"
Old Sep 16, 2002 | 03:55 AM
jond's Avatar
Size doesnt necessarly equal strength. Are they made of the same material?
jond's Avatar
Does your car over or understeer?
Old Sep 16, 2002 | 04:20 AM
Cosworth's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (jond)
I would think 24mm front sway with 22mm ITR rear sway would produce understeer in a GS-R. You need to firm up the rear more (rear strut bar, pillar bar, or a cage), or get smaller front sway bar to compensate for flimpsy rear.
If I were in your situation, I would play with your shock adjustability to dial out the oversteer. (or, add more bars in the rear to firm it up)
[Modified by Cosworth, 8:24 AM 9/16/2002]
Old Sep 16, 2002 | 08:58 AM
reefer_bob's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (Cosworth)
I have the Comptech Rear Sway Tie bar Combo (22mm), the Comptech Front Tie, Spoon Rear Upper Tie, Neuspeed/Koni Yellows and Neuspeed 'sport' Springs. Wheels and Tyres are 16x7 with 205x45 Yoko A520's.
With the stock front, and the oversized rear, plus adjusting the dampers, I have been able to get a very neutral handling car with just a touch of understeer. At higher speeds at the limit with a throttle lift, the back end will come out.
Old Sep 16, 2002 | 01:19 PM
SystemGSR's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (reefer_bob)
Can sombody explain under and over stear alittle more. I'm pretty sure i understand what they are but i just wnat to make sure.
Also the front sway bar is the Stock GSR one. The rear is ITR. (like i've said many times). What do you guys think of the Cusco Tower bars.. The gsr front tower bar is hallow and sucks. and it doesnt have a rear tower bar.
Old Sep 16, 2002 | 01:37 PM
Type Goch's Avatar
New User
Understeer- When you're going into a turn but your back end just doesn't want to rotate. Lack of traction in the front wheels as well. Instead of going the direction you want, you pretty much go straight. I'm sure others can give better explanations though.
Oversteer- Rotation of the rear.
Sorry for the lack of clarity, i'm sure others can give better explanations.
[Modified by Type Goch, 2:38 PM 9/16/2002]
Old Sep 16, 2002 | 01:47 PM
rainmanEK's Avatar
big strong guy
Default Re: Sway Bars and Strut Tower Bars.. (Type Goch)
honda's dont have struts, lets start calling them tie bars!!
Old Sep 16, 2002 | 06:08 PM
SystemGSR's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (rainmanEK)
up up up, i'm not satisfied
Old Sep 16, 2002 | 06:19 PM
Tweakmeister's Avatar
Get tie-bars front and back, on the bottom.
(Neuspeed, Tanabe, etc.)
and strut-tower bars for the front and back, on the top.
then get shocks. Bilsteins or Koni Yellows, and some springs like H&R Sports.
Old Sep 16, 2002 | 07:06 PM
SystemGSR's Avatar
Default Re: Sway Bars and Strut Tower Bars.. (Tweakmeister)
jesus, are you guys even reading the posts before you reply to them...
Old Sep 17, 2002 | 09:39 AM
reefer_bob's Avatar
ANYTHING you can do to stiffen the chassis of the car is good. I would recommend tie bars. Front Upper, Rear Upper, and Rear Lower.
I wouldn't recommend upgrading your front sway bar unless you've got a huge rear sway bar. A bigger front will cause the car to understeer more.
austinkli
Suspension & Brakes
Mar 22, 2010 07:00 PM
fluke83
Jul 8, 2004 10:05 PM
fluke83
Jul 6, 2004 03:13 AM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
spork sport
Feb 22, 2002 03:51 PM
