1993 civic si hatch, Severe electrical issue
Old Jul 16, 2010 | 06:24 PM
93slmdcvcsi's Avatar
Default 1993 civic si hatch, Severe electrical issue
I have a 93 civic hatch, bought the car as a shell. just recently put my swap in and turbo kit, when to start. it would start and run for a while. here comes the issue. All of a sudden, i loose all power throughout the whole car, no lights, beeps, buzzers, etc. The under hood fuse box seems to getting power from battery, but nothing inside the car, anyone have any ideas? let me kno 540-241-2036 mike
Old Jul 16, 2010 | 06:32 PM
Former User's Avatar
Default Re: 1993 civic si hatch, Severe electrical issue
Try cleaning and tightening the battery ground wire attached to the frame.
Any hood fuse blown?
Old Jul 16, 2010 | 06:57 PM
i hav tried that like 5 times, any other ideas, lol
Old Jul 16, 2010 | 07:00 PM
Do the headlights work when the problem happens? If so, check the ignition switch.
Old Jul 16, 2010 | 10:01 PM
kyosoeg6's Avatar
never had one blow but have u looked at the main relay?
Old Jul 16, 2010 | 10:07 PM
Dual-500's Avatar
My 91 hb had similar syptoms and I replaced the electrical switch part of the ignition switch - all is now well.
Old Jul 17, 2010 | 02:17 AM
i hav replaced main relay, and tried a new ignition switch, and still nothing. Everything worked for a lil while, then i unpluged the MAP sensor, and replaced it with hondata 4bar, repluged it, and then nothing!
Old Jul 17, 2010 | 07:40 AM
Dual-500's Avatar
Oh boy, this is going to be fun. Intermittent total electrical collapse. Probably best it's a total fail. Should be easier to isolate - not that it's going to be easy.
I don't know man. I assume you have schematics for the thing? Sounds like a connection, solder joint, corrosion, rust, what have you.
About all you can do is start at the battery and work through the systen wire by wire, joint by joint.
Alternator is working ok? Voltage is good? If it's good, and it's going dead while in the run mode, then the issue is after the alternator/battery circuit.
Old Jul 17, 2010 | 08:29 AM
Originally Posted by Dual-500
Oh boy, this is going to be fun. Intermittent total electrical collapse. Probably best it's a total fail. Should be easire to isolate - not that it's going to be easy.
Alternator is working ok? Voltage is good? If it's good, and it's going dead while in teh run mode, then the issue is after the alternator/battery circuit.
I dont think you understand.... There is nothing, no start, no lights, horn, buzzer, crank, NOTHING!
Old Jul 17, 2010 | 09:15 AM
apexi_rsx's Avatar
sound like the power to the fusebox is bad. run a hot wire to it see what happens.
Old Jul 17, 2010 | 10:16 AM
Also could be a bad hood fuse box.
Old Jul 17, 2010 | 10:17 AM
Dual-500's Avatar
I understand. Good conversation with you.
Good luck with it.
Old Jul 17, 2010 | 11:47 AM
thanks, i appreciate the concern. not to many people wanna help anyone anymore!
Old Jul 17, 2010 | 02:01 PM
after a whole lot of searching, i hav found the problem! but I am in need of a 92-95 EG cabin harness, lmk if anyone out the has one or is willing to look for one, thanks again
Old Jul 17, 2010 | 06:30 PM
Dual-500's Avatar
Why a whole harness? Did it smoke some insulation? Burn wires? If it's just one bad wire simply piggy back one along with it.
If it's burnt, melted then yes change the whole thing out.
Glad you found it hoss - I figured you would soon. It was a good thing is just dumped and went totally dead - easier to figure out.
Go to the WTB or classified forum and post what you need. Someone will probably have it.
Good talking to you again - as the conversation progressed you unwound a bit. It served as moral support as much as technical. Been there done that.
Cheers to ya!
Old Jul 17, 2010 | 07:19 PM
well it appears that it is only 1 wire, and i thought about cutting it out and trying to replace it, but it was alot of work just to get to where i could see it, lol. had to take the blower assembly, heater core, etc out. has really been a pain in my @$$.
Old Jul 17, 2010 | 07:28 PM
Dual-500's Avatar
Did it burn insulation? If it heated from a short and smoked the insulation, it may have melted adjacent wires. If it's all inside the bundle, then you probably should replace the harness just to be sure.
That's a judgemet call and maybe a mirror inspection will help. I would just piggy back one outside the bundle if doesn't look too bad. But, if it's hosed up then replace the whole bundle.
You could put a jumper in temporarily and get the car going while you search for a replacement.
Again, it's a judgement call.
In the long run, it's probably not worth trying to repair. I'd not be too worried about a jumper though, for temporary testing - just cut the other wire out of the circuit at each end and cap them good.
I'm glad you found it hoss!
Old Jul 17, 2010 | 08:03 PM
bigD's Avatar
The car is tuned for the 4 bar map correct?
Old Jul 17, 2010 | 08:30 PM
EusebioSam19's Avatar
bumpp
Tido831
Jul 10, 2018 09:39 AM
NOSblast
Nov 12, 2012 10:17 AM
carnot
Jul 9, 2012 05:28 AM
wpgredteg
30
Oct 18, 2010 11:50 AM
greyeghatch
Jan 7, 2009 08:28 AM
