Car Won't Start/Dizzy Not Firing
Old Jul 16, 2010 | 03:05 PM
sLyBlAzNbBoI's Avatar
Default Car Won't Start/Dizzy Not Firing
Ok, I'll try to be as informative as possible. I just completed a jdm b16 swap into my 92 EG, and it won't start. I'm pretty sure my fuel pump is not malfunctioning because every time I crank the car I can smell raw fuel from the bay. I took off my cap and rotor and I did see some corrosion on the rotor, and a lot on each of the little mini-tabs on the cap, but I don't think that's enough to stop the dizzy from firing? I really can't think of anything else that could be hindering my car from starting. I'd appreciate any help I can get guys. And this might be irrelevant to my problem, but does this plug I have circled in red hook to anything?
Old Jul 16, 2010 | 06:01 PM
Former User's Avatar
Default Re: Car Won't Start/Dizzy Not Firing
CEL codes?
Have you checked for spark at the plugs?
The plug may be for the O2 sensor or back up lights.
Old Jul 16, 2010 | 06:11 PM
Well, the CEL is on when the key is in the "ON" position, but so are all of the other lights on my gauges. And the spark plugs are brand spanking new. They've actually seen no spark-time since the motor's never actually cranked up with them in. =/ And now that I think about it, I'm pretty sure that empty plug does go to the back up lights. My friend took out the back up light wire.
Old Jul 16, 2010 | 06:17 PM
Jump the service connector to pull the CEL codes. See forum CEL sticky.
Click Spark link in my signature to learn how to check for spark.
Old Jul 16, 2010 | 06:25 PM
Hmm, what fuse are you talking about in this section? "Check whether battery voltage is reaching the coil and igniter wire (often a Blk/Yel wire) in the distributor when the ignition key is turned to ON(II). If not, there may be a bad wire or a blown fuse in the under-hood fuse/relay box. A bad ignition switch is another possibility." I ask because my shell came with a shaved bay, so my under-hood fuse box is located behind my glovebox. Also, thanks for the links bro.
Old Jul 16, 2010 | 06:29 PM
If your fuel pump primes, don't worry about a blown fuse. Start by checking for spark and pulling the CEL codes.
Old Jul 16, 2010 | 06:30 PM
Ok, thanks bro.
BSERIESDARRYL
Apr 15, 2017 07:27 AM
gerbsgsr
15
Dec 28, 2015 08:46 PM
fmxrydr
Oct 30, 2014 06:05 AM
dj-t
Jan 27, 2011 05:55 PM
JAYDmManny1331
Nov 22, 2009 09:33 PM
