Dash light help
Old Jul 15, 2010 | 08:33 PM
sleEKcpe's Avatar
Default Dash light help
Question to those with aftermarket radios in ek.. Is there a certain place to hook up the illumination and dimmer light wires to get dash lights to come on with headlights...my dash lights are still not coming on. I do know my constant wire is probably fried, so I hooked a wire directly to the battery..PLEASE HELP!!!
Old Jul 15, 2010 | 08:56 PM
Former User's Avatar
Default Re: Dash light help
Is 7.5A dash fuse 30 blown?
Old Jul 15, 2010 | 09:02 PM
sleEKcpe's Avatar
Fuses are good...I got a harness that connects to the factory harnss so I could wire the stereo up and there is a illumination wire and dimmer wire but they don't plug into anything...hense no dash lights
Old Jul 15, 2010 | 09:06 PM
Do the cluster lights work?
Old Jul 15, 2010 | 09:10 PM
sleEKcpe's Avatar
No none of dash..although I touched those two wires to the constant off the battery so I know the lights work...just a matter of where to hook the illum and dimmer wires to... Is there a relay I can tap into from the headlight switch
Old Jul 15, 2010 | 09:12 PM
Pry the dimmer switch out of the dash and unplug it. Then use a jumper wire to short the red wire to the black wire in the wire harness plug. Do the lights now work?
Old Jul 15, 2010 | 09:29 PM
sleEKcpe's Avatar
[QUOTE=RonJ@HT;43038995]Pry the dimmer switch out of the dash and unplug it. Then use a jumper wire to short the red wire to the black wire in the wire harness plug. Do the lights now work?
Tried didn't work
Old Jul 15, 2010 | 09:37 PM
[quote=sleEKcpe;43039124]
Tried didn't work
Did you turn the light switch on? If so, check whether the red wire terminal has battery voltage to body ground and whether the black wire has continuity to body ground.
Old Jul 15, 2010 | 10:01 PM
sleEKcpe's Avatar
yea lights on nada...checked voltage...nada... im wondering if the illumination wire and dimmer wire from the radio harness need to be plugged in to power them...thats what im trying to figure out...and if so where do they need to be plugged
Old Jul 15, 2010 | 10:04 PM
Check installed dash fuse 30 for voltage to body ground at both top test tabs with the light switch on. Click Test Fuses in my signature. There should be voltage at both tabs.
Do the taillights work?
Old Jul 15, 2010 | 10:08 PM
No, the cluster lights should still work even if the radio dimmer wire is disconnected.
Old Jul 15, 2010 | 10:12 PM
sleEKcpe's Avatar
even the dash illumination wire???its not a radio illumination...its the red and black for the dash.. it should still work??? also just to make sure fuse 30 is to what exactly
Old Jul 15, 2010 | 10:20 PM
All dash lights on the dimmer circuit must be wired to both the Red/Blk wire and Red wire, the same wires you see in the dimmer switch connector. Where did you cut the Red/Blk wire?
It protects the circuit for all dash lights controlled by the dimmer switch.
Old Jul 15, 2010 | 10:29 PM
sleEKcpe's Avatar
i didnt cut any wires...my car had a cut radio harness when i got it, so i bought an oem harness. then i bought a mid harness to connect to the oem to my stereo harness. both harnesses i bought have wires that connect to the dash illumination(red/black) and dimmer(red). but there is no where to plug the wires into my stereo(aftermarket). so thats where i am...trying to figure out where to run the wires off the harness to get the lights on??? thanks for all ur help by the way...2 minds think better than 1
Old Jul 15, 2010 | 10:39 PM
sleEKcpe's Avatar
https://honda-tech.com/forums/audio-security-video-27/need-help-dimmer-illumination-wire-hook-up-2175312/
this is the same problem i have but i added radio harnesses...also my white/blue wire(supposed to be 12v constant does not work...not a hot wire) i added a wire off the battery much like for an amp and i use that as constant...but still need dash lights thats y im wondering what wires i can maybe tap into to add power to at minimum the dash lights could care less if i can adjust the brightness
Old Jul 16, 2010 | 06:05 AM
What year Civic?
The Red wire and Red/Blk wire must have battery voltage with the light switch on. If not, you won't have cluster or dash lights. You need a multimeter to sort out this problem. Do these tests with the light switch on (Parking lights is fine):
1) Check for battery voltage to body ground at both top test tabs of installed fuse 30. Both tabs should have voltage.
2) The two power wires at the dimmer switch plug run to connector C507. Is it connected?
3) The Red/Blk wire at C507 runs to connector C501 that plugs into the dash fuse box. Is it plugged in?
4) The Red wire at C507 runs to connector C411. Is it connected?
5) The Red wire at C411 runs to connector C440 and then to connector C723. Are they both plugged in? Is the heater control panel connector plugged in?
6) At C440 and C723, the Red wire changes into the Red/Blk wire, which runs to connector C419 that plugs into the dash fuse box. Is it connected?
This is where to start. The next step is to test the Red wire and Red/Blk wire for voltage at each of the connectors above.
Old Jul 23, 2010 | 09:23 AM
toyomatt84's Avatar
Sanji
Thanks for the quick tutorial, RonJ. It saved me a bunch of time in research, and helped me solve my problem on my new daily driver.
88cr-rex
Apr 20, 2024 11:43 AM
JasonYo
Aug 16, 2009 06:32 PM
rafimos
Audio / Security / Video
Nov 5, 2002 09:01 PM
ControlNode
Mar 11, 2002 07:41 PM
ControlNode
Mar 10, 2002 07:47 AM
