TPS sensor help
Old Jul 15, 2010 | 10:46 AM
cranker's Avatar
Default TPS sensor help
I need to set the voltage on a TPS sensor I put it on and it keeps setting the engine light off. Is their a how to I did a search and it came up nothing. I never done it before I need to get this car working properly any point in the right direction would be mint
Old Jul 15, 2010 | 11:34 AM
Former User's Avatar
Default Re: TPS sensor help
The TPS has three wires: Power, ECU input, and ground.
Turn the key to ON(II) and, in the connected TPS plug, back probe the ECU input and ground wires with a digital multimeter. Adjust the position of the TPS such that you measure ~0.5V at closed throttle and ~4.5V at wide open throttle.
Old Jul 15, 2010 | 02:00 PM
delsolproblems's Avatar
The TPS setting doesn't cause the TPS CEL. Code 7 pops up when the ECU loses the TPS signal. You have a loose or broken connection somewhere.
Old Jul 15, 2010 | 03:22 PM
96DelSol's Avatar
Your sure your map and tps arent switched?
csunny95
Sep 20, 2018 10:15 AM
8600RPM
Nov 11, 2011 03:23 PM
Jakester9500
Nov 19, 2008 07:10 AM
ScottEK
Jun 12, 2006 06:02 AM
OwnsAnAcura
Dec 24, 2005 06:05 PM
