Need help! Clicking from behind glovebox!
Old Jul 14, 2010 | 10:35 AM
loljoev's Avatar
Default Need help! Clicking from behind glovebox!
I've searched and searched, but i can't find anything about this anywhere. I have a 97 Civic. If it matters, it's a 5-speed DX coupe.
Ok, so there's this strange clicking from behind my glove box. Starts when i turn the key to On, stops while the car is turning over, then resumes while the car is running. There appears to be a metal arm (for lack of a better term) that's supposed to rotate on a white motor that it hooks onto. I can't find it anywhere in my repair manual (must be the crappy Chilton i got...). The car starts, runs and drives fine...i just have no idea what this infernal clicking noise is! It's fairly loud too...so you can embarassingly hear it from the outside of the car. It's not the main relay (thank god). Space is pretty tight, and my camera sucks...so i can't get a picture of it. It's to the left of the main relay, sort of in the middle of the glovebox, but behind it.
It gets stuck trying to rotate the arm around. The motor seemingly wants to spin in a circle, and gets stuck when it's at the top of the circle. Any thoughts? Is there another relay back there that i'm not aware of? I'm sorry if my description sucks...i've been fighting with this thing for 2 hours now...and i'm fed up!!
Old Jul 14, 2010 | 10:43 AM
Former User's Avatar
Default Re: Need help! Clicking from behind glovebox!
Post a picture. Are you talking about the blower motor at the bottom of the blower unit?
Old Jul 14, 2010 | 11:06 AM
loljoev's Avatar
Ah! Thank you for directing me! It is the "recirculation control motor" that seems to be acting up. I never would have figured HVAC...haha.
All that does is open and close the flap right? If i disconnect the arm from the motor, is the only negative going to be that i'll only be able to recirculate the air from inside?
Old Jul 14, 2010 | 11:17 AM
Until you are ready to fix it, just unplug the electrical connector from the motor.
Old Jul 27, 2010 | 09:40 PM
onebad4D's Avatar
Hi. It's a common problem for the recirculation motor to malfunction. It is a failed component on the internal control board. I had the same problem on my 88 Accord. I reverse engineered the circuit and fixed the problem. It's worked great ever since.
areed6
Honda Civic (2006 - 2015)
Mar 12, 2011 07:39 PM
D-Rob
16
Oct 13, 2006 10:05 AM
hnp5
Sep 1, 2005 10:03 PM
TurboxDC2
Jun 21, 2004 10:27 PM
mr poo
13
Oct 19, 2003 07:24 PM
