pr3: rev limit and vtec ingagemenet:please
8200 rpm fuel cut off. Water temp above 110F,VSS above 25mph, and 5200 rpm, then vtec is enabled. You must have 50psi of oil pressure too. This is for the 5million series, the PWO 1 million series have a 4700 rpm vtec engagement, along with the AT ECU's.
niether, your best bet is to chip a PM6 to have the mapping for vtec. You don't want to use a DOHC vtec ECU on a SOHC vtec engine.
i rather have the PM6 taken and be Zdyne'd wich its going to be better and they will program it the way according to ur needs...
