insanely low dyno numbers h2b please help
Old Jul 14, 2010 | 12:21 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default insanely low dyno numbers h2b please help
dyno'd my h2b h22 ef monday and it made 133whp/127tq tq fell off at 4800 rpms. the bottom end is fully built 89mm at least 12 to 1 comp. stock cams, intake manifold and megan racing header. the afr's are still outta wack (high elevens to mid 12's) brian at forged didn't wanna waste any more of my $ tuning it when something was obviously wrong.
31 degrees timing on s300 through the upper rpms.
pulls 20-21#s of vacuum at idle.
motor doesn't smoke at all, still fresh (under 200 miles)
throttle response is right on and its snappy. I must say it scoots pretty good for such low numbers. but its still missing ALOT of power. Im going to compression test it tomorrow to see if that will show me anything. he thinks that maybe the cam timing is off. crappy thing Is with the h2b I can't run a lower t belt cover.
if any one has any ideas please post them. even if you think they might be dumb, we were both scratching out heads.
Old Jul 14, 2010 | 01:16 AM
Combustion Contraption's Avatar
Default Re: insanely low dyno numbers h2b please help
High-cam not engaging.
Old Jul 14, 2010 | 03:19 AM
OH_1fstgsr's Avatar
YEP, NO VTEC.
Check eveything relating to VTEC, the VTEC Solenoid screen might be dirty. Make sure oil is full.
Old Jul 14, 2010 | 06:36 AM
pleej's Avatar
check the vss too
Old Jul 14, 2010 | 07:03 AM
bemanuel's Avatar
I would have to agree with this. Sounds like there is a vtec issue.
Old Jul 14, 2010 | 08:34 AM
mouab18c1's Avatar
Aren't his cams outa whack for his compression?
Old Jul 14, 2010 | 10:39 AM
SL0WEGG's Avatar
Stock cams wouldn't effect it like this.
Old Jul 14, 2010 | 11:04 AM
Loved
Community Favorite
Im pretty sure vtec is engaging. brian said it was. its at 4k and you can just barley hear it. I will try to clean it all out. Im gonna be pist if I just got it tuned on the low cam.
Old Jul 14, 2010 | 12:17 PM
h23V's Avatar
On stock cams can be from 180ish to 210 with the proper bolt ons and tune. U should have asked ur tuner what was the map sensor at at wot what colomns it was in. Sounds like a restriction somewhere or possible a map sensor out of whack.
U can diagnose alot of things using the tuning software datalogging and seeing if one of the sensors is off or not giving the right calibrations.
But also do that compression text and a possible leakdown asap and let us know.
Old Jul 14, 2010 | 12:24 PM
You could just be hearing some resonance in the intake system at 4k. TQ peak @ 4800rpm is a pretty good indication its not engaging VTEC. Remember, VTEC could be electrically engaging, that is, the solenoid receiving a signal and opening, but mechanically there could still be a problem, like an oil orifice left out of the head that regulates oil pressure on the rocker arm shafts for example.
Old Jul 14, 2010 | 12:27 PM
h23V's Avatar
x2
Old Jul 14, 2010 | 05:27 PM
Loved
Community Favorite
I pulled the vtec solenoid off and it was full of aluminum shavings in the screen. cleaned it out and runs about the same, Im gonna do a valve adjustment and pull the middle cam holder thing to see if that o-ring is there and what not. Im gonna do some logs in a little bit when it cools down a bit too
Old Jul 14, 2010 | 05:28 PM
Loved
Community Favorite
also looked at the dyno graph and the tq falls off after 5100 not sure if that changes anything.
Old Jul 14, 2010 | 06:27 PM
h23V's Avatar
yea sounds like the vtec isn't working b/c that's were the low cam should fall off and with those stock cams u would most def notice the cross over not really well. But make sure u have all the bolts in the cam holder's make sure that they are not backwards they should be in order 1 2 3 4 5.
Old Jul 14, 2010 | 06:44 PM
h23V's Avatar
Thanks to 98vtec here is a dyno with h22 dyno low cam only.
Does ur graph look like this.
Old Jul 14, 2010 | 06:53 PM
91' LS-VTEC's Avatar
had a similar problem. Check your oil orifice.
Old Jul 14, 2010 | 07:29 PM
q16racer's Avatar
who is that idiot?
________
Dc medical marijuana dispensary
Old Jul 14, 2010 | 09:04 PM
Loved
Community Favorite
awesome you guys are very helpful. I got alot of crap going on right now but Ill update when I figure out what the deal is with everything.
Old Jul 14, 2010 | 09:05 PM
Loved
Community Favorite
and yes that looks alot like my graph
Old Jul 14, 2010 | 09:10 PM
h23V's Avatar
Originally Posted by q16racer
who is that idiot?
And y am i an idiot. Really did i do something wrong b/c all this internet typing flapping ur gums is real nice.
Old Jul 14, 2010 | 10:22 PM
DDTECH's Avatar
your a cool guy h23v, but you need to do alittle research..i dont think everyone knows, but i'll say it because I have blakes back..
q16racer = 98vtec.. just a FYI.. so h23v ;P
Old Jul 15, 2010 | 02:09 AM
Loved
Community Favorite
Im pretty sure you guys were right. cleaned out the solenoid and did a oil change on it. went out to make sure it engages and it does but only in first and second. Im gonna add a qt to qt and a half to make sure that doesn't happen. I made some afr adjustments and it ripped tires off hard in first and second
Old Jul 15, 2010 | 02:37 AM
h23V's Avatar
Yea i know that he changed his name i'm just wondering y he said that. I know he does say bone head things alot. I only provided a dyno with low cam so maybe he could compare his problem to the dyno.
Old Jul 16, 2010 | 08:48 AM
Garrett's Avatar
when you are on the dyno
do a run with vtec activated, do another without the vtec activate
compare both, you're supposed to see it
Old Jul 16, 2010 | 09:48 AM
colocho19's Avatar
the ecu is reading that it open's up but it might not actually be opening up, it happened to a friend...
