Does rocker arms have to be installed in same position?
Old Jul 13, 2010 | 10:34 PM
raidacaipo's Avatar
Default Does rocker arms have to be installed in same position?
I swapped my b20 head and used an ls head. The question is however, do I need to make note of the rocker arms and make sure they are seated in the same positions as when I took them off? They all look the same and the numbers don't make sense either
Old Jul 14, 2010 | 02:54 AM
apexi_rsx's Avatar
Default Re: Does rocker arms have to be installed in same position?
set the bottom end to tdc and cam at TDC before installing
Old Jul 14, 2010 | 10:55 AM
raidacaipo's Avatar
yes I already know that thanks for the tip but the question is do I have to set the rocker arms in the same position as when I took them out? They have numbers on them but the numbers dont make sense. Like some of the rocker arms have "0" and "4" on them. But there are like 3 rocker arms with the number "4" on them and 2 rocker arms with the number "0" on them. It doesnt make sense.. Does it matter which rocker arms are place in which position? They all look the same to me.
Also for example, the cam holders have numbers and pointers on them so you have to put them in the same position.
Old Jul 14, 2010 | 11:05 AM
Mashimaro's Avatar
they should go back in the exact same order/position.
Old Jul 14, 2010 | 01:37 PM
raidacaipo's Avatar
see thats the problem. I got them mixed up and now Im trying to get them back in the same exact position but theres no guide to doing it. The rocker arms don't have an order to put back into position like the cam holders do. The numbers on the rocker arms are so random. Like I have 3 rocker arms with "4" on it and then I have 2 rocker arms with "0" and then I have only 1 rocker arm with "1" and another 1 with "8" on it. It doesn't make sense at all.
Old Jul 14, 2010 | 02:31 PM
cjw_89's Avatar
You poor unfortunate bast**d.I done the same thing.Checking for bent valves.If i had my time back i woulda hauled the top pan off in my car and used it for a refrence.See if you can find a buddy who has an ls motor in the garage somewhere.Then haul the top pan off and go from there
I was going to post it at the time i FU**ED up but i just sold the engine for $100 after.
Old Jul 14, 2010 | 08:33 PM
raidacaipo's Avatar
So the correct rocker arm placement is necessary? I even read the manual and it says just keep the rocker arms in the same position you took it out from and note it. However, I have a b20 block with an ls head. I basically transfered all the rocker arms, the cam holders, cam bolts, and the camshaft over to the ls head. So would it still matter if the rocker arms are in the correct position and just do valve adjustment afterwards?
Old May 5, 2014 | 02:51 PM
JL2's Avatar
JL2
Do I need to make note of the rocker arms and make sure they are seated in the same positions as when I took them off?
Guys I know this is a 4 year old thread, but im desperately enough looking for the answer.
I need a solid or more technical answer for this problem.
Old May 5, 2014 | 03:03 PM
gsrturbo-ek's Avatar
yes your suppose to keep them in the same locations but if you mixed them it should be ok also just do a Valve Adjustemt after putting it together
Old May 5, 2014 | 03:21 PM
NotARaCist's Avatar
I never narc'd on nobody!
No, they don't strictly have to be in the same position. Yes, you do have to do a valve lash adjustment after removing them.
Old May 5, 2014 | 06:05 PM
tony_2018's Avatar
Fish Twig
Why the hell would you ask idiotic questions like this, get straight to the point on what you fucked up on dude and then we can help you from there.
Since the damage is done you will need to do a valve lash adjustment at cold temps.
Old May 6, 2014 | 05:46 AM
JL2's Avatar
JL2
Thanks buddy i appreciate it,Now it clears my headache
Its time for valve adjustment. :D
Old Aug 2, 2021 | 01:36 PM
Johnnyd213's Avatar
can I put rocker arms back any way if I mixed them up after taking them oi ff
Old Aug 2, 2021 | 02:02 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This was already answered in the thread you necro bumped. Read a few posts back from yours and you will have your answer a couple times over.
chrisnick
Dec 15, 2014 11:14 AM
98h22
Mar 9, 2006 10:48 AM
EFin' Kyle
Nov 28, 2004 03:51 PM
Jdm93civic
Aug 24, 2003 10:47 AM
SonicGSR
Oct 12, 2001 09:20 PM
