1990 Honda Accord smells like fuel while driving, shitty mileage, and idles rough
Old Jul 13, 2010 | 06:12 PM
GREENMOB$TER's Avatar
Default 1990 Honda Accord smells like fuel while driving, shitty mileage, and idles rough
My Accord smells like fuel while driving, and really bad after fueling at a station. It idles very rough when at lights, or stop signs but is fine drving. I get very shitty gas mileage as well. Any idea what this is?
Old Jul 13, 2010 | 06:32 PM
viera's Avatar
Default Re: 1990 Honda Accord smells like fuel while driving, shitty mileage, and idles rough
what have u dont to the car? check plugs & timing i had a very similar problem
Old Jul 15, 2010 | 12:45 PM
aviator1683's Avatar
i have the same problem with my 1991 accord. can anyone help?
Old Jul 15, 2010 | 01:29 PM
4671 Hybird's Avatar
Check your fuel hoses, make sure there aren't any pinhole leaks. What about the fuel filter, when's the last time you changed it? I'd also take a look at each spark plug, maybe you have a sticking injector...
Old Jul 15, 2010 | 01:54 PM
holmesnmanny's Avatar
id check the fuel pressure regulator for a o-ring leak, myself
Old Jul 17, 2010 | 07:39 PM
fleetw00d's Avatar
On my 90, the main supply line from the tank rusted out at the rear end of the cluster of five lines that run under the car. There is a cover over all the fuel connections on the left side of the tank. When you fill up next time, turn the ignition on/off several times to pressurize the fuel line, then take a good look under the car near the tank to check for drips. New fuel line fixed this one.
On my 93 wagon, had a fuel injector seal leaking. Same procedure for this (might work better on a cold engine so the fuel doesn't evaporate so quickly). Ignition on/off several times, the sniff/feel around the fuel connections under the hood for fuel leaks. New seals on the injector fixed this one.
Old Jul 23, 2010 | 08:02 AM
MISDEMEANOR's Avatar
I know this has nothing to do with ur topic but.....me and my dad have a 91 honda accord sedan. It has a manual,power windows and stuff like that......anyway im trying to convince my dad to modify it a little so what should i say.....
Old Jul 23, 2010 | 10:02 AM
I know this has NOTHING to do with ur topic but......me and my dad have a 91 Honda accord sedan LX with a manual (it's funny when we smoke someone in a STOCK Honda)
anyway im trying to convince my dad to modify the car a bit.....what should i say.
Old Jul 23, 2010 | 10:06 AM
sorry i didnt see the first post my bad
Old Jul 23, 2010 | 11:40 AM
Bwill9886's Avatar
Please do not thread jack. It is not polite and against forum rules. If you have questions, go post in an appropriate thread, PM someone so as not to clutter this thread anymore, or make your own thread. Thank you.
Now OP, as viera asked, what has been done maintenance wise? There could be a couple things that would lead to this condition so we need to narrow this down.
Old Jul 23, 2010 | 01:07 PM
5thgenlude29's Avatar
fuel filter or injectors i would say
Old Jul 23, 2010 | 01:30 PM
ES2Kerv's Avatar
For the rough idling, I'd say to readjust the throttle under the hood. My Accord used to do the same, as well as my mechanic's. He has a '91 sedan (EX) and I have a '92 coupe (LX).
Old Jul 23, 2010 | 02:06 PM
sorry, I bought the car for a couple hundred dollars, it has 236k miles. Nothing done since I bought it.
Old Jul 23, 2010 | 02:11 PM
im a new member....i can't post a new thread until 5 days after i signed up.
Old Jul 23, 2010 | 06:02 PM
Bwill9886's Avatar
No maintenance records? Damn, well I guess it's time to start throwing things out there...
There could be several culprits or maybe just one (though it sounds like at least two).
Definitely troubleshoot your ignition and fuel system as others have suggested. Any CEL's?
The idle could be the IACV or TPS (or a few other things but those are often the culprits).
How is the exhaust looking? Any leaks you can hear or see? Idk, there are so many things that could be causing your many symptoms... Just start trying some of these and report back.
Also, do you know if the car's ECU had been messed with at all? Know if any motor swaps were done? You could have a bad ECU/badly wired ECU/wrong ECU. Just some food for thought...
They have this in hopes that new members might search the site, learn the rules, and find their answer instead of posting a thread that might be unnecessary. Obviously it doesn't always work that way.
Anyway, this is a tech forum. Your post is not even tech related. Please go to the General Discussion forums at the bottom of the main page. Thank you.
Old Jul 24, 2010 | 02:51 PM
No CELS, no leaks. Im selling it in a week to my friend, he wants it. Thanks guys
endless22
Oct 9, 2010 06:45 AM
jeebus520
Jul 9, 2010 10:15 AM
C_H_A_D
Aug 28, 2006 05:09 PM
kevinl34
Dec 27, 2005 10:44 PM
Nufusion1
Sep 13, 2004 09:07 AM
