Drag/street buildup ...what turbo? ,setup inside
gsr block
a.e.b.s sleeves ,bored to 85mm
wiseco 8-5-1 pistons
eagle rods with big rod bolts
fully balanced and blue printed
oem honda type r oil pump
oem honda type r water pump
gates timing belt
gsr head
blox 76mm throttlebody
elderbrock victor x intake manifold
supertech dual valve springs
supertech nitride valves
bronze valve guides
3 angle valve job
mild port and polish job
cams -getting millers magic stick cams
fuel setup
dual bosch 044 pumps
efi wizard 2000cc injectors
sx performance fpr
aem fuel rail
as for the turbo itself im not sure what i want to go with my main goals for the car is to run 9.50's and trap 160 plus in the quarter
i was looking at the 372r and the pte6768 but im not sure what back housing's and stuff to be looking for hp wise im looking to make 800whp or better
gates timing belt
gsr head
bronze valve guides
3 angle valve job
fuel setup
sx performance fpr
aem fuel rail
i think 8.5:1 compression is going to kill your lowend. i'd say 9.0:1 to even 10.8:1 compression will yield better results at lower boost levels.
i have to laugh when i see a drag/street setup and then having an s372 as a tuebo option.
i wouldnt want to drive that turbo on the street hahaa.
honestly i think 800 on the street wont be fun. but thats my 2 cents. (well it will be and we all know that.)
i guess i should say practical on the street.
400whp on a 372r? i wouldnt want to drive that.
im pretty sure there are other options out there. i dont know everything about every turbo inbetween. so i cant really offer anything technical. daughters crying. time to feed her hahaa.
Get the billet 6765 or 6768 ball bearing with the .96a/r hot side, make plenty of power, and still have good enough spool to be fun on the street.... 6765 will spool a bit quicker, and should still be good enough to reach your goals...
i was also reading up on the s372r turbo. sounds like a really good turbo for 9's. can anyone give input on that vs the s400sx BW? i get confused reading back and forth between the 2 if theyre the same or different..
GL on your build
GL on your build
I'm in the minority probably but I love my s372r on the street. I have the 1.25 a/r. I ride around on pump gas and make about 500whp on 15lbs. I have a 2.0L motor now, but it spools faster than a 57 trim did on my b16.
sidenote I did a boost leak test on my car today and my 76mm blox throttle body was shitting a ton of air out the side from the shaft. Did some research and apparently this is common...but just a FYI for you in case you care.
JDMH22Prelude
Jun 22, 2006 09:44 AM
