Do OBDII ECU's have 4 plug ports?
Old Sep 15, 2002 | 01:34 PM
Jonathan_ED3's Avatar
Default Do OBDII ECU's have 4 plug ports?
Can anyone confirm this?
I have a P75 ECU and I'm trying to determine if it's OBDI or OBDII.
It has a total of 3 plug ports.
Old Sep 15, 2002 | 01:45 PM
Kataku2K3's Avatar
Default Re: Do OBDII ECU's have 4 plug ports? (hot_EG)
OBD2 ECU's have four plug sockets but only use 3 of them at one time... 96-98 OBD2a uses the first 2 and the farthest right one (A,B,D) 99+ OBD2b uses (A,B,C). All you have to do to know if the ECU is OBD1 or OBD2 is look at the pins in the female sockets on the ECU. If they are stacked 3 high then you have an OBD2 ECU if they only have two stacks then it's non OBD or OBD1. Hope this helps
Old Sep 15, 2002 | 02:00 PM
Default Re: Do OBDII ECU's have 4 plug ports? (JDMspecEG6)
man thanks a TONNNNN
this is exactly what I was looking for!!!!
Thanks SO much
Old Sep 16, 2002 | 05:51 AM
boomslang's Avatar
OBDIIa (96-98 civic, 96-99 integra) uses plugs A, C, D
OBDIIb (99-00 civic, 00-01 integra) uses plugs A, B, C
Old Sep 16, 2002 | 09:51 AM
Trey's Avatar
25 Year Member
Default Re: Do OBDII ECU's have 4 plug ports? (Inlinefour)
Unless the ecu is a automatic tranny ecu, then they use all four plugs.
Old Sep 16, 2002 | 10:07 AM
boomslang's Avatar
Default Re: Do OBDII ECU's have 4 plug ports? (Trey)
Correct. But who drives an auto?
Old Jun 23, 2012 | 12:37 PM
g_monkey's Avatar
i got a question what ecu has 4 plug
Old Jun 23, 2012 | 12:40 PM
g_monkey's Avatar
i have a ek civic b20 motor but auto and i need an ecu with 4 plugs car will not shift when driving
ShortbusEK
Aug 4, 2005 06:13 AM
tspkenneth
Mar 28, 2004 03:59 PM
stnwag0n
Jan 24, 2004 09:06 PM
BruceLee
Nov 11, 2001 08:25 PM
