Trunk floor cover?
Old Jul 13, 2010 | 07:37 AM
Zombie Nachos's Avatar
Default Trunk floor cover?
What up!? I was wondering what material the floor of the trunk is made out of? Like the wood or that thick cardboard material lol. Not sure what it is but I need that and was wondering if I could get it at like Home Depot or Lowes or something like that. I'm totally lost on this. Any help would do!
Old Jul 13, 2010 | 08:13 AM
BlueIntegraBoy's Avatar
Default Re: Trunk floor cover?
Like plastic cardboard for a lack of term
Old Jul 13, 2010 | 08:16 AM
JDM_SOHC's Avatar
I went to Lowe's and got 1/8" thick plywood, and used my friends to trace out the shape and cut my own... Works perfect, and if you spray it down good with water repellent before hand it will help prolong the life and keep it from warping... GL..
Old Jul 13, 2010 | 08:17 AM
apexi_rsx's Avatar
but a thin piece of plywood or something and cover it with fabric
Old Jul 13, 2010 | 10:37 AM
Cool...yeah. I was thinking plywood would work but wasn't sure. I'll try out the plywood with the water repellant and see how that works! Now to find how it's shaped lol! Thanks!!!
Old Jul 13, 2010 | 11:04 AM
BLVD. kreeper's Avatar
i got one in good condition at the junkyard....for free too for my eg
Old Jul 13, 2010 | 11:37 AM
I've already called every junk yard around and near here. Nobody even has a hatch in the yard. So that idea went out the door quick lol.
Old Jul 13, 2010 | 01:16 PM
NOFX's Avatar
H-T White Ops
It's like a heavy duty pressed cardboard. Or a flexible particle board.
Coupe/sedan trunk boards can be cut into hatch ones. The coupe and sedan bodies are just 10 inches longer than hatches, all through the rear end.
I've personally made a trunk board for a hatch out of one for a coupe (which is the same as a sedan).
I'm talking about 6Gs in particular, but it might work for 5Gs too.
Old Sep 17, 2010 | 12:55 AM
NOFX's Avatar
H-T White Ops
Since I found this thread in my search results too... Maybe this will help someone later on down the road.
https://honda-tech.com/forums/showpo...5&postcount=29
Originally Posted by NOFX
I couldn't find this image when I saw this thread, but just found the image again and remembered your questions.
Here is a photo, along with measurements, of my stock '98 Civic coupe trunk board. This would be the same shape for any '96-'00 Civic coupe or sedan.
I don't immediately have the measurements for a hatch here, but here is an image of a hatch trunk board (from the eBay link above).
I have personally taken a '96-'00 Civic coupe trunk board and cut it to fit perfectly into a '96-'00 Civic hatch. So if you have a hatch and find a '96-'00 coupe or sedan trunk board, you can make one to fit the hatch out of that. Just cut the front of the board off.
(Front of vehicle is at the BOTTOM of the image for this pic.)
Old Sep 17, 2010 | 06:26 AM
94EG8's Avatar
Seagull Management
For anyone that wants to know the factory trunk floor is made out of masonite.
/used to work at a hardware store
Old Sep 17, 2010 | 06:35 AM
Crashtestdummy's Avatar
i looked at the prices of the replacements for the hatch, the actual one that will fit, dude, follow their advise build your own lol
Old Sep 17, 2010 | 07:43 AM
TwoFacedCustoms's Avatar
x2
You can borrow one from a friend or something...trace it out...and cut with a jigsaw. The whole project from start to finish...maybe 20 minutes if you really take your time and smoke a cigarette between the tracing and cutting.......
Old Sep 17, 2010 | 10:00 AM
NOFX's Avatar
H-T White Ops
Dork!
Okay, so I'd actually heard before what it was made out of but it was totally not something I would have retained since I'd never heard of masonite before that point.
Any idea of a product that one could use that would still be smooth and lightweight like the OE board, but stronger? I just don't know what I'd use. I've never worked at a hardware store/home improvement store/finishing store and never really got the home improvement bug quite like the rest of my family.
Old Sep 17, 2010 | 10:55 AM
ArtyG's Avatar
I have since trimmed the carpet to fit over the hinged "door". I used two 4'x8' sheets from Lowe's, cut to fit in the trunk.
ribal_gh
Sep 25, 2012 10:00 PM
INVALID
Honda S2000
13
May 27, 2009 10:26 AM
Nata$
Oct 27, 2006 06:27 PM
broketuner-Sol_Si
Jan 20, 2006 12:37 AM
Grease Monkey
Apr 26, 2004 04:40 PM
