98 Ek Question
Old Jul 13, 2010 | 12:04 AM
TheCivicMafia's Avatar
Default 98 Ek Question
Okay im trying to get another short block to rebuild with my rebuilt head.
Im having a hard time finding one thats not outrageous
My motor is a d16y8 ( obd 2 ofcourse )
My question is, Ive found 2 D16z6 Blocks How hard would it be to use this block with my head, ( im not going for preformance, just dd ) Being the z6 is obd1
If you got an immediate answer, TheCivicMafia@gmail.com / 850-258-9939 txt me I trust in ht not to spam my inbox lol.
Old Jul 13, 2010 | 04:09 PM
Default Re: 98 Ek Question
No one knows?
Old Jul 13, 2010 | 04:15 PM
DVDr's Avatar
Are you staying OBD2 ? , you can make the block work. a few sensors are missing. Mainly the one on the front oil pump crank angle . so you would need to use an obd2 oil pump.
But the majority of the sensors are on the head part.
Are you dropping the full motor, or using the block and swapping on your y8 head ?
The few people I have seen with z6 blocks in obd2 cars are running obd1 ecus tuned.
Old Jul 14, 2010 | 02:48 PM
Yeah, im staying obd2 for now.
D16y8 Head ( Im keeping )
D16z6 block ( im trying to use )
Ive got and extra obd2 oil pump Is that all i need to change? On a y8 block theres a sensor under the intake manifold part ( on the block ) What about this one?
Old Jul 14, 2010 | 03:27 PM
-__-'s Avatar
You can use the block, it wil be fine. You can switch over an OBD2 oil pump OR just bypass the crank sensor (google search). The sensor on the back of the block that i believe u are talking about is the knock sensor.
Old Jul 15, 2010 | 12:02 PM
Hmm i dont like that bypass method looks ghetto. And ghetto is not the way to do things. Causes problems down the road.
Old Jul 15, 2010 | 02:05 PM
DVDr's Avatar
then easiest way is installing the obd2 oil pump setup . the other sensors are the same.
knock
oil pressure
waster temp
etc .
Yuleluder
Nov 1, 2005 07:53 PM
pearl
May 24, 2005 09:38 PM
whoa its len 2
Oct 2, 2004 07:18 AM
Br1anPham
14
Sep 6, 2004 11:20 AM
