Completed 5 speed swap, Now have a bad vibration.
Old Jul 12, 2010 | 08:46 PM
ej8ster96's Avatar
Default Completed 5 speed swap, Now have a bad vibration.
As the title states. I did my swap about a week ago and now i have a bad vibration in the steering wheel. i balanced my wheels and they were still dead on. Not sure what the problem is. Also my tires rub alot more now than b4. Help??
Old Jul 12, 2010 | 08:50 PM
infinitypro12's Avatar
Default Re: Completed 5 speed swap, Now have a bad vibration.
Did you change your springs in the front? What engine did you swap in?
Your tow or camber may be off. Installing the new engine, depending on what you had before, may be heavier and without proper springs to support it, it might have thrown your tires out of whack.
Old Jul 12, 2010 | 08:53 PM
ej8ster96's Avatar
It was an auto y8. Now its a manual y8. Never swapped the springs. Only change was the 5 speed swap. Motor stayed the same.
-__-'s Avatar
did the axles come apart when u did the swap? also check the axle nuts, upper and lower control arm nuts, and lug nuts.
Old Jul 12, 2010 | 08:55 PM
ej8ster96's Avatar
Axles came out for the swap. I have tightended all the nuts and bolts that there is. Im dumbfounded.
Old Jul 12, 2010 | 08:59 PM
90civichb's Avatar
Doing an auto to manual swap should not have any bearing on your tires.
Make sure that all of your engine mounts are in properly and tightened. Having a bad/loose engine mount can cause serious vibration issues.
Old Jul 12, 2010 | 09:00 PM
ej8ster96's Avatar
The transmission tourque mount was not installed simply cuz i forgot to get one. But i dont think that would cause that kind of vibration.
Old Jul 12, 2010 | 09:13 PM
EsotericImage's Avatar
Retired Moderator
^^ you'll be surprised
Old Jul 12, 2010 | 09:17 PM
90civichb's Avatar
So before putting a torque mount in place, you want us to blame it on something else?
No offense man, but you should try the easy stuff before posting online and asking for help...
Old Jul 13, 2010 | 03:06 PM
ej8ster96's Avatar
I just didnt think the mount would cause that kind of vibration.
Old Jul 13, 2010 | 03:19 PM
F4MzEkSOL's Avatar
i did a auto to 5spd swap on mines i dont get no vibration and plus i dont even have lower torque mounts maybe your engine mounts are getting worned out
Old Jul 13, 2010 | 03:20 PM
ekhatchling's Avatar
Mount is there for a reason., esp one called "torque" mount. You'd be surprised how much movement can happen with just one bad mount.
Old Jul 15, 2010 | 05:28 AM
ej8ster96's Avatar
I replaced every mount with oem mounts. I also got the lower torque mount. Still vibrating.
Old Jul 15, 2010 | 07:02 AM
matt96ex's Avatar
did you change the axles when you did the swap? could be that. try putting your auto axles back in if thats the case.
Old Jul 15, 2010 | 08:39 AM
RedHatch00's Avatar
also when you did your swap, did you get the right mount for the manual tranny? the mounts are different just for the tranny, the manual mount sits a little lower than an automatic tranny.
Old Jul 16, 2010 | 11:56 AM
ej8ster96's Avatar
i reused the auto axles.
yeah. i went to honda and got them.
Old Jul 16, 2010 | 04:23 PM
snake_eyes's Avatar
unbalanced messed up axles...
Old Jul 16, 2010 | 04:54 PM
Linked's Avatar
does the car vibrate when at a stand still, if so its not the axles
i did the 5spd swap on my d16 eg and did not use the front lower torque mount(simply because the nuts inside the frame it bolts to broke off...)
check to make sure your top mount isnt hitting the body
check to make sure your rear torque mount isnt doing anything
did you properly install the clutch and pilot bearing?
Old Jul 18, 2010 | 04:34 PM
ej8ster96's Avatar
both axles are practically new. and the clutch and pilot bearing were installed correctly. it vibrates pretty roughly from like 65-80. after 80. it barely vibrates.
Old Jul 18, 2010 | 07:01 PM
rogue420's Avatar
Tire separation?
Old Jul 18, 2010 | 11:01 PM
ej8ster96's Avatar
Originally Posted by rogue420
Tire separation?
tires only have like 8k on them. they shouldnt be seperating
Old Jul 19, 2010 | 12:29 AM
burnykawizzle's Avatar
your missing 1 mount.... wow thats pretty bad if your asking us on honda tech whats wrong with the car. maybe you should ask yourself why you didnt put that mount on...its like having a bicycle without a seat. you want to ride on it but you just dont know how to ride it without the seat so you start asking around
Old Jul 19, 2010 | 12:45 PM
ej8ster96's Avatar
Dude seriously, fall off the face of the earth. I didnt put it on cuz i thought the auto and manual torque mounts were the same. I have the mount on now. Hasnt changed.
Old Jul 19, 2010 | 03:38 PM
did you tighten everything? are you missing any screws? rev up your motor high and check if the engine moves and if it does then change your motor mounts.... that should do the trick if not you need to explain more about the issue
Old Jul 19, 2010 | 04:36 PM
ej8ster96's Avatar
everything is tightened. every mount is new.
