somone want to host a dyno chart of my turbo ITR?
I have a dyno of my ITR Turbo but I dont know how to post a pic. I will give you a run down of my setup though before the chart goes up. I only have about a $1000 in the turbo kit, maybe a touch more but not much. Junkyard is the way to go!
98 ITR at 7psi
Stock block
stock headgasket
stock head with GSR cams
Junkyard T3 oil and watercooled turbo from a Chrysler LeBaron .48ar exhaust and comp. 50 trim wheel.
Starion Intercooler painted black
LHT Performance custom piping some 2" some 2 1/2"
Bosch BOV
SFP manifold
SFP 2.5" downpipe
Mugen exhaust
Test pipe
Zdyne Gold Ecu
Endyn ported Intake manifold
DSM 450 injectors
Greddy Profec B
HKS wastegate with 5.7psi spring
Thats everything in the power area. Double thumbsup to Zdyne, car runs like normal.
This turbo is fantastic, spools up very quick and is a blast to drive.
Also, double thumbsup to John at Secret Services for the dyno time and to John Wilson at LHT Performance who is the one who made it all happen.
scott
[Modified by scooter, 8:06 PM 9/15/2002]
98 ITR at 7psi
Stock block
stock headgasket
Bosch BOV
SFP manifold
SFP 2.5" downpipe
Mugen exhaust
Test pipe
Zdyne Gold Ecu
DSM 450 injectors
Greddy Profec B
scott
Hey send it to Sswinger15@aol.com I will put it on my server.
tell me how to post the pic and I will. I have it on We-Todd.... but I dont know what to do with it from there.
scott
scott
how much did you spend in all of those toys ??
Anyway, kickass for only spending $1000.00 for custom setup bro. Too bad almost 300$ of it was for the Profec-B. Could've had a turbo setup for under 800$ with a MBC.
Not sure on the cams, I didnt do a R cam vs. GSR on the dyno. From everything Ive read seems that the GSR were the better way to go.
Yes better than blower, however I didnt have Standalone with blower so that would make a difference.
scott
scott
Hey how much was the Manifold and Downpipe? Will it fit a T3 super 60 and fit between a fluidyne radiator and the engine?
Thanks
Nicola
Thanks
Nicola
you put down some great numbers!!! i have seen less with systems that costs 3 times what you spent!!!! where are you located and which junkyards did you go to.
