cable transmission
Old Jul 12, 2010 | 02:08 PM
SAXON's Avatar
Default cable transmission
I was wondering if anyone has put a cable transmission into your civic and how you did it? i have seen some kits that allow hydraulic slave cylinders used with a cable trans?
Old Jul 12, 2010 | 03:28 PM
DRAMA's Avatar
Default Re: cable transmission
Just use a custom mount on the passenger side for the transmission to the frame rail mount. Then you'll need a custom bracket to hold the hydrolic clutch on the cable arm so it'll push it downward.
Old Jul 12, 2010 | 04:04 PM
SAXON's Avatar
the lever pulls up on a cable trans so i would need a special slave that has enough throw and a way to have that mounted
is there a mount kit?
Old Jul 12, 2010 | 04:37 PM
Deetz's Avatar
Crazy Honda Guy
Cable tranny's used to be a lot cheaper, and people would go that rout with a different mount kit. These days, even hydro tranny's are cheap, so why bother
Old Jul 12, 2010 | 05:04 PM
cjw_89's Avatar
Maybe he has an lsd cable gearbox lined up for cheap or already has one from a previous vehicle.Heres a link that i spent a long!!!!!!!!!!! time looking for when i was making a conversion kit.It is the only link i could find of the h/c conversion kit installed hope this helps. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/emma-under-construction-my-hatch-build-2494140/
Its justabout at the bottom of the page.Its fairly simple to make i used some 3/8 metal and cut it out to the best of my ability to match his.Then i used washers to shim it correcty.Then used a tie rod end out of a ski doo with an adjusting shaft.It worked perfectly.I rigged up a mount as well.That wasn't so pretty.
Here was my monstrosity
I never knew i still had them hope this helps
Old Jul 12, 2010 | 05:29 PM
SAXON's Avatar
thanks alot, thats what i was hoping to do
to be honest i have an awd D series cable trans and its the only way to go, i have a pretty heavy duty clutch and want to convert the whole system over to hydraulic to make it a little easier and less to worry about (cable stretch, bending pedals etc)
Old Jul 12, 2010 | 07:19 PM
cjw_89's Avatar
im pretty sure you can buy just the mount for the top pass side.There will be some shifting issues where the 90-93 cable gearbox dosent share the same lower torque mount.You wil also have to change over your vss.
Old Jul 13, 2010 | 03:59 AM
SAXON's Avatar
trans is in a cable car already so i will be converting the whole car, but figured this would be a good forum to make the post since most cable cars dont need nor want to convert
Old Jul 13, 2010 | 05:58 AM
cjw_89's Avatar
so what exactly are your plans.Putting a cable trans 88-91 civic into a 92-95 hydro say...??
I wouldnt not advise you to try and covert your whole system out.Ive read up on this and attemted to do a cable swap on a 95 teg ls.Its Far tomuch work.Thats why thier are conversion kits out there .Now the c/h conversion is something you wouldn't be able to create so easy.It i worth looking it up on google its kinda freaky.Make a post on this to get people to post up thier conversion kits sure.
Old Jul 13, 2010 | 06:17 AM
SAXON's Avatar
no, my plans are to convert a 91 si into hydraulic system and keep the cable trans since its awd
Einhander276
16
Feb 9, 2011 02:03 PM
Maleek
Jan 3, 2010 03:44 AM
WHITE DEATH
Jan 3, 2006 11:23 PM
biassj
Mar 6, 2004 05:22 AM
4ghatch
Jun 6, 2003 06:17 PM
