hydraulic clutch
why would anyone want to do this. if your cable tranny is in good working order then leave it be, if you need to replace it and can only find a hydro tranny then swicth it out..
clutch isnt the problem, i need it to hold the power
the problem is i dont want to bend pedals and stretch cables, let alone hydraulics help with pedal pressure
EDIT: just so you know, the higher the stage, the FIRMER the clutch pedal, regardless if it is cable or hydro.
yes i realize that, although my post count is low ive been a member since 01 (coptzer, earldasquirrel... but they wouldnt let me change my name)
i have had many stage 5 comp clutches with hydro and they were manageable, whereas im losing too much time just trying to push in this pedal
its an awd D series trans in a 91 si
haha, either way this thread is fail so i dont car about grammer anymor
EDIT: Oh, maybe you guys could help me with my h22 eg, its got 554hp/456lbs...it isnt starting for some reason! I'm still using my z6 engine harness and i just kind of made the plugs fit into the h22 sensors...i dont know whats wrong.
is this a serious post?
why the off topic? why do i need to prove what i have? why not just help me out?
no one questioned this guy
http://www.youtube.com/watch?v=Qxtf3_IHTfs
