Stock seatbelts with Sparco EVO's
Does the stock seatbelt work with the sparco EVO seats? i remember reading it does, but you just have to buy the more expensive mounts, just want to make sure before i order some...Thanks guys.
they kinda work if you thread the stock belt through the side holes in the seat, but the evo is designed for harnesses....i use my 5-points exclusively. Check S&M to see how i rigged up the stock belts, it was a waste of time since i never use them
Aleph -- I'd probably have gotten a ticket for a 5-pt if I'd been using one that last couple times I'd been stopped and issued my 6 (other) tickets.
[Modified by Zygspeed, 6:22 PM 9/15/2002]
yep, stock seatbelts don't work well with sparco evo's. you can rig them up but it's not easy slipping the stock belt through the right side hole when you're in the seat. i recommend just going 5 point! i got pulled over by ny's finest and he didn't mention the harness.
BDogggUT34
29
Feb 9, 2007 09:19 AM
REFLUX
Jul 19, 2006 12:44 AM
Optiks.
Sep 5, 2003 02:23 PM
