1999 civic d16y8 clutch not disengaging
Old Jul 12, 2010 | 10:45 AM
ride5150's Avatar
Default 1999 civic d16y8 clutch not disengaging
so a couple days ago i grinded gears when i shifted from 1st to 2nd, i figured i didnt press the clutch in on accident or something like that. this started happening more and more until i couldnt even get the car into any gears. i shut off the car, put it into first and held the clutch. when i tried starting it the car moved forward even tho i was holding the clutch. i checked the fluid in the master cylinder, its good there are no leaks. theres pressure in the pedal and the clutch fork moves when u depress the clutch, i also just tried bleeding it but that didnt help at all.
help? ive heard that a worn clutch disc can cause this but i dont see how that can be.
what do you think? bent clutch fork?
Old Jul 12, 2010 | 11:06 AM
Former User's Avatar
Default Re: 1999 civic d16y8 clutch not disengaging
Maybe the pressure plate is bad.
Old Jul 12, 2010 | 11:29 AM
cjw_89's Avatar
x2 i cooked mine one day.Tryin to show of grind grind grind.No go
langjairicer
May 1, 2010 12:08 AM
InitialJRift
Sep 13, 2006 10:43 AM
JFG Kevin
Apr 12, 2006 01:56 AM
SpoonFed
Apr 10, 2002 05:33 PM
tinter
Jul 19, 2001 01:06 PM
