A/C Compressor Question
Old Jul 12, 2010 | 06:12 AM
1 Civic I's Avatar
Default A/C Compressor Question
Im about to take my compressor off and just put a new one on. i just had my ac redone. They took it out and put new stuff in it. If i take the compressor of im assuming freon is going to come out of the 2 lines? liquid or gas?
After i get the new one in i have to get the lines sucked back out and then refilled right?
Thanks just wanted to know before i started it.
Old Jul 12, 2010 | 07:35 AM
integra15's Avatar
Default Re: A/C Compressor Question
The refrigerant is a gas. The proper way is to have a shop remove it. Obviously you don't want to remove the compressor without removing the pressure in the system. Once you put the new compressor in you will need to add the proper amount of oil to it. Then have the system vacuumed and charged.
Old Jul 12, 2010 | 08:24 AM
1 Civic I's Avatar
alright thanks. Idk oil level but i guess ill do some research.
Old Jul 12, 2010 | 10:24 AM
1 Civic I's Avatar
okay so i cant get a warrenty on a compressor at autozone or discount because i have to do the dryer and expansion valve new by them and ive already had the expansion valve done by a mechanic so im not gunna buy the part again..?
So i think im going to go try and find a clutch at a junkyard because thats hopefully all i will need sence all my compressor has done was froze up and the pully wont move.
Old Jul 12, 2010 | 11:06 AM
integra15's Avatar
Try to find the Honda service manual for your car. (They are on the internet). In the A/C section it gives all the specs for refrigerant charge levels and oil amounts etc.
Old Jul 12, 2010 | 11:12 AM
1 Civic I's Avatar
Alright will do. My main thing is can I empty out my compressor freon without breaking anything. do i need to go vac it out? I dont have the money to do it the right way , this is my 3rd time bringing it back for ac. In these manuals its not gunna tell me if i can do this because they all want me to do it the right way haha.
Old Jul 12, 2010 | 03:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes you need to have it vaccumed. When you open up the system you introduce air into it. This will not allow you to properly charge the AC system. If you are doing it yourself then I assume that means you are gonna refill it with refrigerant from your local autoparts store, correct? Pretty much all store bought refrigerant has some type of sealant in it which will cause severe damage to your AC system. You will just be going in a big circle. Also no AC manufacturer will warrant a compressor damaged from sealant. Sealant will also be present through out the rest of the AC system and is virtually impossible to remove...
Old Jul 12, 2010 | 07:06 PM
1 Civic I's Avatar
no i was gunna bring it to a shop that did my expansion valve. i did some research that said if you did open up your lines and air got into it they blow out your lines and whatnot then refill it. Idk though and im just gunna do more research till i have everything figured out. no big rush not like my car dont run without it.
Old Jul 13, 2010 | 09:10 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
That is incorrect. They do not blow out the lines, they apply a vaccum to the lines in order to suck out all the air and moisture.
Old Jul 14, 2010 | 05:17 PM
jmjohnson128's Avatar
true, most shops will do it the wrong way and just vacuum for 15-20 mins but the proper way to service the a/c system after a catastrophic compressor failure (locking up) would be to flush the system with a special solvent thats pressurized and like said earlier replace receiver /drier and expansion valve and sometimes on some vehicles you have to replace condensor because the flues in it are too small and will be stopped up by the shavings outta the compressor. sorry i rambled on for soooo long, im buzzing
Old Jul 14, 2010 | 06:54 PM
1 Civic I's Avatar
Okay so today i took of the compressor i met somebody thats done it before and has all the gauges. And vacs. We took off the old one and there where no shavings in the compressor freon fluid. Good deal so where hoping nothing spread throughout.
He had a accord compressor. didnt fit. so we put it all back together an now trying to find a compressor. Might just get a used one. or get one from ebay for like 170 bucks new with 12000 mile warranty or 12 months. discount wants 270 for a new one. and i dont think im gunna go for that.
Let me know what you think. my lines are closed off right now so no bad crap gets in the lines. Hopefully this will be a cheap ac fix.
Wish me luck
Old Jul 15, 2010 | 11:26 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Wish me luck
There are filters available. One goes into the suction side and for the other you need the proper tooling to install. I believe NAPA sells them. Im not sure if you can get them individually as we have a whole filter kit. But they work great and are designed to catch any crap in your system before it spreads.
Old Jul 15, 2010 | 04:00 PM
Old Jul 16, 2010 | 07:56 PM
1 Civic I's Avatar
Yes, he has one. But like i said dont think where gunna do it sence we didnt find any shavings in the compressor or anything.
Ugh i hate waiting for a compressor its do dang hot in florida.
Old Jul 17, 2010 | 12:06 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
If the old compressor froze up and failed I guarantee there is debris in your system that will cause havoc down the road. A filter is cheap insurance.
Old Jul 17, 2010 | 10:32 AM
1 Civic I's Avatar
Ill check into them. Dont know if the person that is helping has the tools, but ill check into it! Thanks!
Old Jul 17, 2010 | 10:35 AM
1 Civic I's Avatar
As im doing research the only ac filter i see is the one behind the glove box?
This the one your talking about?
Old Jul 19, 2010 | 10:50 AM
no he's talking about a filter that is installed in the low side/ suction hose not the cabin air filter
Old Jul 19, 2010 | 05:31 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Correct. OP this filter can be installed by anyone servicing your system. The other filter is placed in line and the line must be cut in order to install it.
Old Jul 21, 2010 | 08:56 AM
TurboBB2's Avatar
did you buy the one off ebay yet? cause i have an ac compressor with 28k miles on it, so basically brand new off my JDM h22 swap. I can let it go for 150 shipped if your interested. im not running ac so i have no use for it.
Old Jul 21, 2010 | 07:14 PM
1 Civic I's Avatar
Damn lol you from daytona again i coulda went and picked that compressor up! and yah i bought it 173 shipped new. Im sorry i didnt read this sooner. working 64 hrs a week..
Old Jul 23, 2010 | 05:48 AM
TurboBB2's Avatar
Oh thats alright im in charlotte anyway i just stated that in your 4ws thread lol..
anyway i have a guy buying it from me so its all good. cant believe im lettin it go for so cheap but eh.. whatever i dont need it lol.
Old Jul 23, 2010 | 02:59 PM
1 Civic I's Avatar
haha i got a cheap one off ebay looks legit just got it today. putting it on tom. see how it goes. rather have a used one then a new one anyways to be honest . I hope everything just works fine haha.
Old Jul 24, 2010 | 12:34 PM
1 Civic I's Avatar
Ac is now working. ebay compressor is the way to go lol.
Old Jul 26, 2010 | 06:18 AM
TurboBB2's Avatar
congrats man
baybay
Aug 26, 2018 02:39 PM
jasrams
Honda Civic (2001 - 2005)
Apr 23, 2012 08:59 AM
1 Civic I
Jul 12, 2010 02:26 PM
Turbo E
Aug 8, 2006 08:59 AM
mingbling96
May 11, 2005 03:11 PM
