your "To Do List"
this kinda plays off the "wrenching your ef" thread.....
I thought it would be fun and interesting to see everyone's to do list on ur ef.
also this would be a great thread to go back onto if u forget anything that u haven't done on ur car!
and please dont put "everything" or "too much to list" or the like!
here's mine:
Fix:
ball joints
Tie rods
Radius Rods
front and rear bushings for suspension
heater control
paint front and rear bumper along with hood
sunroof track
replace rotors *front and rear*
re-upholster seats
Wax and polish the car
sorry if u think this is a dumb thread, but its 2am here and i'm bored and tired -.-
here's mine:
Fix:
ball joints
Tie rods
Radius Rods
heater control
sunroof track
re-upholster seats
Here's mine
get tires mounted and balanced
get it registered and new plates
get insurance
get new tags
replace header gaskets
fix reverse light
fix the rip in my drivers seat
get new alarm LED
wash the car,because its collecting dust
get insurance
get new tags
fix reverse light
get new alarm LED
Mount Innovative crossmember (when it gets here)
Take off stock catalytic converter and put on Blox test pipe (when it gets here)
fint place to mount Tunerview
Put in Walbro fuel pump
Change axle boot
Put on alternator
Put on crank pulley
Put on intercooler pipe and bov
Run vacuum lines
Install wiring harness
Have downpipe redone
Have driverside intercooler piping redone
Get elbow and dump tube made
Get car tuned
Change axle boot
Put on alternator
Put on crank pulley
Run vacuum lines
Get car tuned
91 crx dx---
buy rdx injectors
run hydro clutch line
calibrate wideband
bleed brakes
richen the hell out of the basemap
buy Si-R bonnet
nut/bolt suspension and break in engine for 200-300 miles
...full build thread coming soon
Homemade ITB's (no cut corners), 304 cfm head, balanced/blueprinted b16, 12:1 comp
SI-R lsd gearbox, NSX brakes, hydro clutch, fully tucked bay.
Lude seats, accord climate control (cold A/C), GS-R cluster
All info for the build came from searching this site. All of it.
1.5 yrs in the making...
buy rdx injectors
calibrate wideband
bleed brakes
buy Si-R bonnet
pfft white board? I have a black board,magic markers, and a black light
Buy starter
Solder up ECU wires
start her up
Wash her
clean engine bay
install rear tie bar
install old wheels with new tires
make a new trunk divider thing
and lastly prep for paint
Buy starter
Solder up ECU wires
start her up
Wash her
clean engine bay
ppffffff I don't even wanna think about most of mine, but i'lll do the GENERAL topics:
finish going through and cleaning up ENTIRE wiring harness
install all new ball joints
clean and repaint all suspension parts
brakes
install master poly bushing set
start ordering motor parts
BUILD motor
assemble custom turbo "kit"
Finish cleaning up full interior
Power wash shell
Get shell painted
Order hood, fenders, and front bumper
Order wheels/ tires
redo factory seats/ door panels/ all other damaged interior
Tear open trans to install LSD/ gear ratios that I want
Hmmmm theres a general ballpark so you guys can see how much my project life sucks lol
brakes
BUILD motor
Power wash shell
Get shell painted
Order wheels/ tires
here is mine---90 crx si
replace drivers side knuckle with one from parts car
pull motor off stand
install flywheel and clutch
mate tansmission to motor
install motor/transmission
install carpet
install seats
install front bumper
install exhaust manifold and fix rear exhaust
buy front motor mount and install
install heater/ac deleate/blower motor assemblies
install different injectors
get a new windshield
get tires for my vx wheels
thats all i can think of at the moment but i know there is a ton more
install carpet
install seats
take the grill out of my hatch.....
vacuum the interior of my car " Full of sands"
wash the car, specially my right front tire " my friend puke on it -_-"
try to figure out what the heck is wrong with my alignment "backyard alignment"
put my c pillar back again after i take the grill out of my hatch
my 89 sedan!
fix wrecked door.
get new set of wheels
install alarm.
get new rotors.
get a whole new exhaust system
headers.manifold. etc.. after that just make love to her lmao
fix wrecked door.
install alarm.
get new rotors.
my to-do list spans between 2 vehicles at the moment and right now i'm focusing on the coupe lol. i doubt i'll remember everything but this is what i can think of off the top of my head at this particular moment lol.
ek to do list:
-replace muffed up pass fender and front bumper
-Function Form Type 1 Coilovers
-Rota Slips, Gsr Blades, ?
-Si taillights
-Vitara z6 with parts from fjdistributors. unsure of the turbo but it will have to be large enough to make 400+hp safely :p trying to find an a/c compatible turbo manifold might be a pain in the dick though :/
ef to do list:
-have my dad repaint it
-late gen jdm b20b (same as usdm b20z) probably retain the ls trans cause the gearing is short enough as it is.
-replace more worn out suspension parts lol
ek to do list:
-Si taillights
ef to do list:
fuel pump
swap susp., saets and B18 from my DA
Y1
new carpet
new sound system
coilovers
rquisete I-H-E
driver front fender
wheels,probably Enkei 92s or Diamond Racing
tires
install A/C
etc,etc,etc...
Y1
new carpet
new sound system
coilovers
rquisete I-H-E
driver front fender
tires
install A/C
etc,etc,etc...
--91 crx si--
New speakers
New deck
Replace sun roof
Body work and paint
Buy 2 new rims or 4 different rims
Replace center consol
Fix 2mm hole in seat. Minty si seats till that hole
Paint valve cover
Lower back a little
--wagon--
BUY ONE SOON!!!
New speakers
New deck
Replace sun roof
Body work and paint
Paint valve cover
Lower back a little
--wagon--
BUY ONE SOON!!!
--91 crx si--
New speakers
New deck
Replace sun roof
Body work and paint
Paint valve cover
Lower back a little
--wagon--
BUY ONE SOON!!!
New speakers
New deck
Replace sun roof
Body work and paint
Paint valve cover
Lower back a little
--wagon--
BUY ONE SOON!!!
decide between my fully built stroker b18a1, b20z2 that needs rebuild, or trade them both for a gsr engine
build traction bar/ front engine mount bracket
get a b series cable trans
get obd0 dizzy, and sensors that i need
swap said engines one of them
start body work (considering car is completely gutted)
paint either galapagos metallic, or midori
need to get the car back on the road and drive the dam car its ben down for almost a year,
get radiator and hoses
bleed brakes
get traction bars
install fpr and lines
get battery
bleed brakes
get traction bars
get battery
Start my car, been sitting a while
Spray bees building nest in passenger mirror, been sitting lol
Fix hole in downpipe
Install new skunk2 suspension
Buy butt load of skunk2 engine parts
Install skunk2 parts into spare b16A2
Continue to replace any old or broken OEM part, NEVER ENDING
Wash, rinse, wax, BOOST!
