Differances between B16a and B16a2??
I recently got a B16A. Before i put it in my car i plan on replacing the oil pump, water pump, crank main seal, timing belt, and a couple other things. So my question is since my motor is the JDM version, will the USDM parts from the B16a2 be compatable??
depends if your obd1 or obd2, I believe the obd2 oil pumps have a sensor that the obd 1 ones don't , crank positon sensor or something ? if your obd1 use parts from the b16a3(94-95 del sol vtec) or obd2 use 99-00 si, the rest of the parts are the same for the most part with the exception of the pistons as mentioned before jdms have P30 pistons and USDM uses PR3 pistons thats why you ge the higher compression on JDM b16a
poetter
12
Feb 24, 2005 10:46 AM
