My AP2 Turbo Build
Well I just bought my dream car Honda s2000 bad bitch. After about a month now this thing pulls nice for a stock s2000 but I always knew Once you boost there's no coming back. N/a Sucks lol.
Most Don't Know but boost is a drug:bigeyes:
My goal is 400 hp
Well as I get in the Stuff I will post pics and stuff
Well Be running
Hondata Flashpro
T1 Id 1000cc Injectors
Walbro 255lph
Garrett 60-1 Turbo
Turbo Blanket
ODYSSEY PC680
Tial 38mm Wastegate
Pfab Manifold and Purcell Dp
PurCell Intercooler N Piping Kit
Tial 50mm Bov
Fast-turbo-Return and Feed
Plx WideBand
Plx Oil Pressure Gauge
All Fab work done by Purcell Performance
[SIZE=7][SIZE=7][COLOR=blue]
Before Boost
Ueat1023 My AP2 Stock/Flashpro Run
Watch In hd 1080p
My goal is 400 hp
Well Be running
Hondata Flashpro
Walbro 255lph
Garrett 60-1 Turbo
Turbo Blanket
ODYSSEY PC680
Tial 38mm Wastegate
Tial 50mm Bov
Plx WideBand
[SIZE=7][SIZE=7][COLOR=blue]Before Boost
Watch In hd 1080p
Is that intercooler piping steel? Must be heavy!
Also, from the looks of that, you have the crank case evacuation vacuum line going back into the intake pipe (in this case the charge pipe) as it would on a stock S2000. You're going to be introducing your valvetrain to positive manifold pressure with that route, not vacuum like it was designed for. Bottom line, get that thing outta there before you boost that car!
that **** smokes up after a few WOT pulls dont it? i'd rather run the catchcan/breathertank after i had my cabin fill with smoke after i obliterated a 350z who cut me off back then.
There getting vacuum from the top of the fuel regulator vacuum where there is a nipple from intake manifold the AP2 06+ Doesn't have that nipple because there's no Return System.
As for what pwrofdrm is talking about I have circled in your picture. In your picture it looks like you have a tube running from the charge pipe back into the valve cover. This is not good as now your crankcase will see boost pressure just like your intake manifold. The largest problem that positive crankcase pressure is going to cause you, is oil will no longer correctly drain back into your pan. No oil in pan no oil for pump to pump through your block, no oil in block is bad. Again I am not sure if this is the case but it looks that way in your picture hard to tell though since the picture is fuzzy:
So if this line is indeed hooked up from your charge pipe and now piped into your valve cover undo it. Also why you are at it I recommend getting rid of the other one from your intake mani going to your PCV valve as it is just a matter of time before your PCV valve gives up and starts to allow boost into your valve cover.
Before you blast people about doing it right make sure you hear them out and know for sure you have it right. See the picture of the SS
There's nothing going into the chargepipe is just hanging there.
I think I will run a catchcan 1 from pvc to catch and the other 1 that is hanging, and keep my vacuum source from intake manifold.
staticlude17
Mid-Atlantic (Sales)
Oct 12, 2010 01:02 PM
