Little slip up, need some help
Old Jul 11, 2010 | 12:26 PM
MelJ's Avatar
Default Little slip up, need some help
Car is a 2000 Civic 2dr. Was jacking up the car, and I guess the ground was a little too hot, and just a little too soft. The POS jack slipped and the car basically fell and the weight ended up on the splash guard, which cracked and grazed the fan cover.. Nothing seems to be broken luckily. Although the A/C condenser( PT#80110-S01-A11 ) seems to have been knocked off the bracket. And the fan seems to be a little bent and it won't spin. I don't use my A/C, but I'd like to fix the issue. I'm looking at the condenser issue right now, and it seems I just have to somehow lift and push it back into place. Although this seems right, I'd like to know what steps you guys think I should take to get it back into place. Smart idea to remove and replace the bracket as well?(pt# 80107-S04-000) TIA.
Old Jul 12, 2010 | 09:32 AM
David12's Avatar
Default Re: Little slip up, need some help
did the bracket on the bottom where the condensor sits on get damaged at all?
Old Jul 12, 2010 | 09:35 AM
MelJ's Avatar
One of them I think did. That seems to be the only thing that actually got hit. I got the condenser and bracket back in place. A ziptie did a pretty good job surprisngly. Tacky? Yes. But it works well. Thanks for the reply, though.
sweesiong78
Sep 1, 2013 12:19 AM
chero112
Apr 24, 2011 10:22 PM
XhaloZ
Oct 15, 2009 01:40 PM
dtrtw
Apr 5, 2005 08:54 PM
Jonathan_ED3
Sep 25, 2002 02:06 PM
