New here need Just a little help
Old Jul 11, 2010 | 08:20 AM
kurbage's Avatar
Default New here need Just a little help
Ive searched seem to be having problems but im just looking for a guide / how to on replacing the cam seals on the timing side behind the cam gears. On a b16. If someone could point me in the right direction id really be greatfull thanks.
Or you could just tell me how. I know how to pull and replace a timing belt already but never ran into this before. Can I just pull the cam gears off to access ? Or do I have to pull of the cam retainer plates to ? Also should i loosen the game gear bolts before taking the timing belt off?
Old Jul 11, 2010 | 08:38 AM
dr_latino999's Avatar
Default Re: New here need Just a little help
Retainer plates? I'm used to D-Series where you can pull of the gear, place seal, and call it a day. Hopefully someone can give you an accurate answer for B-Series.
Old Jul 11, 2010 | 09:11 AM
kurbage's Avatar
ya I think thats what there called there the plates that sit on top of the cams
Old Jul 11, 2010 | 10:18 AM
D16SiHatch's Avatar
what you're referring to is called a cam cap. some people say you need to loosen them up to aid in replacing the seal but it's definitely not necessary. it's not hard to do though so however you want to go about doing it. anywho, seal replacement is not any different on a b vs. a d.
Old Jul 11, 2010 | 10:34 AM
kurbage's Avatar
thats good enough for me. So pretty much remove timing belt , cam gears , loosen cam caps , remove replace lil grease maybe ? , and retrq cam caps to 20lbs ?
Thanks for the insight though
Old Jul 11, 2010 | 03:52 PM
D16SiHatch's Avatar
ah wait. you have a b16 so you can't just remove the one cap because it's all one piece.
here's torque specs for reassembly
http://www.team-integra.net/images/B...lderremove.jpg
and yes lube up the seal with a bit of engine oil.
DMCCOY
Jan 10, 2009 04:03 PM
boost hep
Mar 25, 2007 04:02 PM
4DRmafia
Dec 22, 2005 08:45 PM
mtwnfabrication
Aug 10, 2005 12:03 AM
EK4 hatchback
May 31, 2004 08:45 PM
