d15b7 turbo question
ok i am going to do a mini me swap. so the block will be a d15b7 and the head will be a d16z6.. now there is a turbo kit for sale on the board that was off a 1990 civic wagon with a d16z6.. now i now i can only run 6-7lbs of boost at the most
here is the kit
"ive got a complete turbo kit that came off my 90 civic wagon. its an hf manifold w/ adapter (needs redrill for studs), ihi turbo off an 03 wrx, greddy rs type bov, all pippings and big front mount ic, comes with cuplers, etc..
this is how my setup looked like make me an offer"
http://c1.ac-images.myspacecdn.com/i...63cb9fcac4.jpg
heres my questions
would this kit be "bolt on" for my 1994 del sol or would i need to do some work?
do i need some sort of fuel magament. it dosent come with it and i was wondering if i could run my stock d15b7 injectors?
When i do my mini me swap and the turbo will i see significant power gains?
thanks guys
here is the kit
heres my questions
thanks guys
you need to get the motor running properly with the mini me swap before throwing the turbo kit on. i would never use stock injectors at least some 310's or 440's with a chipped ecu. the kit should fit your gonna have to work it out alil but im sure its not gonna fit perfectly but nothing major.
He means that you need engine management. You also need to do a lot more research. There is a lot more to it than just installing a kit and driving it. You could just install it and drive it, but your engine isn't going to last very long. Check out the Forced Induction section.
jdm civic ej1
Aug 28, 2007 03:52 PM
Jamarquis
Oct 18, 2004 05:04 PM
