D16y7 turbo
Old Jul 10, 2010 | 04:37 PM
Guzman.R.M.S's Avatar
Default D16y7 turbo
I have d16y7 with the y8 head on in my compretion is 11.1
in I want to now. What feul to use and who many lb of boost
can put in?
Old Jul 10, 2010 | 04:46 PM
apexi_rsx's Avatar
Default Re: D16y7 turbo
low boost 5-8psi pending on turbo or your gonna have to be using race gas.
Old Jul 10, 2010 | 04:51 PM
etorro71's Avatar
What's up every one I have a d16z6 and I aint got money no money for turbo but I want my car to move what should I do
Old Jul 10, 2010 | 04:53 PM
EJeff8's Avatar
^Nice thread jack. And nothing really, it's a D series.
You can bottle feed it.
Old Jul 10, 2010 | 06:47 PM
phelpsj2's Avatar
the ONLY way to make any d series fast is BOOST
Old Jul 10, 2010 | 08:41 PM
Bwill9886's Avatar
can put in?
Suggesting race gas may be jumping to conclusions a bit early... How about we ask some more questions first?
-Guzman, we need more info on the setup as a whole.
-Has you car been tuned? If not, GET IT TUNED.
Tuning will solve all your problems with driveability and the tuner will tune it for whatever gas you want to use (which will be premium at least). Though if you are truly running at around 11:1 compression just on the motor alone, you are asking for trouble... Again, give us more info on the whole setup.
Indeed a lovely thread jack. I'd tell you to make your own thread, but the subject has been covered so many times I hope you don't. Just don't thread jack again please.
The answer is SIMPLE. For "real" power you can:
-Hook up nitrous (which won't give you THAT much power) and probably end up having to rebuild it later on (not that nitrous just kills motors, it's usually the inexperienced user that does).
-Save your money until you can go forced induction.
It's that easy. Bolt-ons will get you no where, but if you want them, go ahead. Just don't expect neck-breaking power AT ALL.
Old Jul 10, 2010 | 09:09 PM
chewyv's Avatar
pm4nudes
can put in?
feul? fuel? feul? fuel? Use any kind of fuel you want and max your boost. Make another thread later on how it went.
Old Jul 10, 2010 | 09:10 PM
chewyv's Avatar
pm4nudes
Save up.
Old Jul 10, 2010 | 10:29 PM
EsotericImage's Avatar
Retired Moderator
Originally Posted by chewyv
Save up.
Fast
Cheap
Reliable
^^ pick 2 and the 3rd is what its not.
Old Jul 11, 2010 | 10:28 AM
phelpsj2's Avatar
save up...do it right the first time so you dont got to be rippin apart several motors. if u want it cheap just build the bottom end..keep the head stock.. peice together ur own kit. go autoworks has alot of good stuff. and get a TUNE...thats where reliable will come from.
Old Jul 11, 2010 | 11:34 AM
aresti40's Avatar
you can just put the engine out and buy vitara piston, eagles rods, acl duraglide bearings and arp studs, and you will have aprox 300whp at 18 psi with 94 octane, depend on the turbo and fuel supply you have. When this setup is done properly this is a setup very reliable and rellly fun to drive on the streets.
Old Jul 11, 2010 | 01:16 PM
i have my head eith blox reteiner and sprind and im using the crower stage 1# cam. for the block i have the racing bearings and the forge rods but the only thing is no forge is the pistons and i have my M/T lsp
Old Jul 11, 2010 | 01:57 PM
Bwill9886's Avatar
That's great and all, but from what I'm gathering the OP has enough to figure out besides dealing with a vitara setup.
Ok... your post is kind of hard to understand but I guess I get the jist of it.
You still didn't answer how your compression was calculated (whether that's with turbo or N/A). That is VERY important for being able to give you more advice.
How will you be tuning the car?
Old Jul 11, 2010 | 03:36 PM
BrandonR's Avatar
Nope. Later, BR
Old Jul 11, 2010 | 05:49 PM
D Griff's Avatar
Originally Posted by EsotericImage
Fast
Cheap
Reliable
Haha, I like this, it's very true. I'm running cheap and reliable right now and loving it.
Old Jul 11, 2010 | 05:55 PM
phelpsj2's Avatar
u must not be very fast then lol jk jk...
Old Jul 11, 2010 | 07:55 PM
11.1 is the compretion in the engine without the turbo
Old Jul 11, 2010 | 07:58 PM
So, how much power it will make in that compretion
Old Jul 11, 2010 | 09:39 PM
Bwill9886's Avatar
Well frankly I wouldn't even turbo it at that compression. That's really high for a turbo build and you will end up having to use e85 at the VERY least.
Regardless I can't imagine that being a very good setup, especially for the street.
You'll make at least in the low to mid 200whp range, but that's really irrelevant as I doubt it will hold together very well. Even if it did I doubt you'd be happy with it. Compression in the 9 range would be a good to shoot for, even 10 if you really want.
Old Jul 12, 2010 | 05:27 PM
apexi_rsx's Avatar
cylinder pressures with that high compression and boost with no sleeves is not too smart.....
Old Jul 17, 2010 | 07:32 PM
the94eg's Avatar
Recently just went through the same thing when a customer brought a car to me. He had a Y7 with a Y8 head, compression was around 10.6:1.
Boost was not really an option at that point, at least not reliably. I recommended a Y7 head (which is easily found) an swap it back, which will bring the compression back to a mear 9.5:1. If you want the cheap way to turbo that motor, just ARP head studs, fuel injectors, regulator and pump. All can be purchased cheaply and have a GOOD tune put on it and you should be fine around the 200hp range.
Old Jul 17, 2010 | 08:27 PM
EusebioSam19's Avatar
agreed lower compression or its gonna blow
Old Feb 14, 2011 | 04:33 AM
thanks
Old Feb 14, 2011 | 03:06 PM
split_second650's Avatar
was the 11:1 static or running? cuz if its static, the running compression will always be lower than that figure due to valve overlap, im tryna do the same 10.5 CR with low boost, its possible, u jes gotta know wut ur doing. still researching ..
oh yeah the y8 heads good for fighting detonation since it was designed to, u jes gotta figure out wut parts to use to ur advantage, wut piston to run for good flame propogation, yada yada yada, its confusing ..
Old Feb 14, 2011 | 08:00 PM
SLURS's Avatar
pics?
